Replacing window seals
I'm getting ready to replace the window seals on my 930 cab. I ordered the follwoing seals:
1. Targa, Cabriolet Window Slot Seal, includes the 5 mounting clips, left and right 2. Targa, Cabriolet, Window Outer Seal, left, 911/912 (1968-89). Must be 24 1/2 inches. Left and Right 3. Targa, Cabriolet Vent Window Cap / Corner Seal, left and right(1974-94) 4. Brass Rivet for vent window caps Is there anything I should be aware of when changing the seals? Do I need any special tools? Also, while I have the doors apart I'd like to lubricate the window regulators. What kind of grease should I use for this? And does anyone have pictures of what I should lubricate? I've never even seen the inside of the door. Oh, I was also thinking about installing sound padding like dynomat. Any tips or ideas regarding this? Thanks in advance! |
The first thing you should do is ask a moderator to move this over to Technical.
Otherwise looks good. |
I reposted in the technical forum.
| All times are GMT -8. The time now is 05:14 AM. |
