-   -   Question concerning Axle Ratio (http://forums.pelicanparts.com/off-topic-discussions/235441-question-concerning-axle-ratio.html)
fireant911 08-10-2005 02:12 PM
Which axle ratio provides the lower engine rpm at the same driving speed assuming that the transmissions are identical: 3.73 or 4.10?
I have always been under the impression that the larger that the axle ratio was the lower geared the vehicle was. I am looking into purchasing a truck and in reviewing the sales brochure the following data is stated - for an axle ratio of 3.73 the maximum loaded trailer weight is 2,640 lbs whereas an axle ratio of 4.10 is 2,500 lbs (which contradicts my previous assumption). Since I will not be hauling anything on a regular basis I want to have the most economical platform.
I am currently looking at a Ford Ranger Edge - any input here would be appreciated also.
IROC 08-10-2005 02:47 PM
3.73. The lower the number numerically, the "taller" the ratio. Your impression is correct.
Rear end ratio isn't the only thing that affects towing, but you're right, I would expect the 4.10 rearend to tow a little better.
Mike
