TSNAPCRACKLEPOP's Avatar
stripped plug on bike
i blew the center plug out of a triple 4 stroke 750cc dohc yamaha. procedure for a dependable fix is??????? do i remove the head ????????????
thanks!!
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 08-17-2005, 08:25 AM
Senior Member
Only way that I know of is to pull the head. You might be able to repair it but no way without getting far too much metal shavings inside the motor otherwise.
JoeA
Old 08-17-2005, 08:33 AM
i suspected!! thx
Old 08-17-2005, 08:34 AM
Kevin Taylor's Avatar
Just plug the hole. That bikes to dangerous and fast anyway.
Should run just fine on the other cylinders.
Don't you have an old mini bike you could have just as much fun on?
K.T.
1973 911E 2.4 MFI
1983 911 SC
1965 Devin "D" - 1967 912 Power Plant
1997 GMC Z-71 4X4
Old 08-17-2005, 10:26 AM
Platinum Member
dad911's Avatar
i've know of a 944 stripped plug being repaired at the track. I think there is a way to plug the hole so the shavings don't drop in. Or could you turn the bike so that the plug hole faces down?
Old 08-17-2005, 06:53 PM
stripper
also had a mechanic tell me to put an oily rag for stickiness in the hole, drill, helicoil, remove rag with hemostats. Just have never done this before. any links to this procedure? When i was on the road, i tried some jbweld type stuff, the quickset, but it lasted about 2 miles. probably did not let it cure for the 30 minutes tho....and surface may not have been optimal clean.
Old 08-18-2005, 07:22 AM
I thought you did that on the old Volkswagons all the time.
Old 08-18-2005, 11:25 AM
Sell It ....As Is.........And Get On The Bus.
Public Transportation Is The Ticket With The Gas Prices Going Up.
K.T.
1973 911E 2.4 MFI
1983 911 SC
1997 GMC Z-71 4X4
Old 08-18-2005, 11:39 AM
among my more intelligent cohorts, the consensus seems to be helicoil, with head on.
my brothers however, will more than likely be sucking down my beer while i do the work.
Old 08-19-2005, 07:40 AM
Was it the center plug?
Old 08-19-2005, 07:56 AM
yep. it is at approximately a 45 degree angle out the right side of the head from the middle.
Old 08-19-2005, 08:02 AM
So it points out of center so you can get to it without engine being removed?
Old 08-19-2005, 08:33 AM
when the tank is on, you can remove the plug out thr right side, with the tank off it is quite accesible. i will send you a pix of a head off ebay
Old 08-19-2005, 08:37 AM
