Senior Member
What am I doing wrong with searching on the forum?
Trying to search for "3.6 conversion" in the 911 tech section and keep getting this error message : "Sorry - no matches. Please try some different terms. "
Problem is that I know that there are several 3.6 conversion threads!
Trying to find out what everyone is doing for sway bars on their converted cars but cannot find the threads!
thx,
Joe A
Old 04-07-2010, 06:49 AM
Bandwidth AbUser
Jim Richards's Avatar
I wonder if the search engine pukes on the "." in 3.6.
Jim R.
Old 04-07-2010, 06:51 AM
Bandwidth AbUser
Well, it can't find "." in my previous post.
Jim R.
Old 04-07-2010, 06:53 AM
Cars & Coffee Killer
legion's Avatar
Does putting quotes around the term "3.6 conversion" work?
5 liters of VVT fury now
-Chris
Old 04-07-2010, 06:55 AM
Bandwidth AbUser
FYI, the quotes around the period didn't work, Chris. Ref. my post preceding yours.
Jim R.
Old 04-07-2010, 06:57 AM
notfarnow's Avatar
I ran into the same thing when searching for 3.2 valve issues, and asked Wayne about it. The search function won't take any search terms that are shorter than three numbers/letters. If I remember correctly, it's because smaller terms would make the search function much slower.
'03 Carrera 4s
+ a whole bunch of boats
Old 04-07-2010, 07:09 AM
Senior Member
Jim, when I search for "3.6 conversion" the search engine changes it to "3.6" conversion and still finds nothing!
Do not understand this at all...
Old 04-07-2010, 07:11 AM
Senior Member
Also searched for "3.6 liter conversion" and same thing.
Bandwidth AbUser
Joe, here's what I think is going on (need Wayne to confirm/deny):
When you enter 3.6, the search engine ignores the "." between the "3" and the "6" and then it gives up on the search because "36" is too short of a word or phrase, based on Wayne setting the search engine to look for entries of at least three characters in length.
Does this sound plausible?
Jim R.
Old 04-07-2010, 07:21 AM
Bandwidth AbUser
Test: 3.6x
Jim R.
Old 04-07-2010, 07:22 AM
Dueller's Avatar
Here's a few results on a search I just did...have to ssift thru but many 3.6 threads included
Pelican Parts Technical BBS - Search Results
Jim
1987 Carrera
2002 BMW 525ti
1997 Buell Cyclone cafe project
1998 Buell S1W: "Angriest motorcycle I've ever ridden."
Old 04-07-2010, 07:23 AM
Bandwidth AbUser
The search engine works for my test: 3.6x. I think my explanation above is right on the money. Not that it helps you any. Sorry about that.
Jim R.
Bandwidth AbUser
Eureka! Joe, use the following to search: 3*6
The "*" is a wildcard character which will pick up the "." and give you the desired 3-character minimum search term.
Jim R.
Old 04-07-2010, 07:33 AM
notfarnow's Avatar
awesome, in your own small way, you just helped make the world a better place!
'03 Carrera 4s
Old 04-07-2010, 07:35 AM
Bandwidth AbUser
Thanks Jake.
Jim R.
Old 04-07-2010, 07:36 AM
Senior Member
Great, thanks much!
Old 04-07-2010, 07:40 AM
