Need Help with PPI
Hey wise porsche men,
I am doing a PPI for a friend ( I was a mechanic over the summer) on a 94 Honda Accord. Anything major I should look for? Any help would be appreciated. |
Fart can hanging straight and "Type R" sticker?
J/K - Timing belt and water pump been done. Water pump impeller (if coolant isn't flushed) has tendency to rot out internally, so no leaks but no water circulation either. rjp |
Thanks for the help Randy! What exactly is this water pump impeller?
inside the water pump, looks like a fan - circulates the water when driven off the timing belt..
rjp |
actually, I'd get the car hot and check the upper hose for a surging. If it surges it should be OK. Look inside the radiator and make sure it's green.
rjp |
| All times are GMT -8. The time now is 05:21 AM. |
