-   -   Neighbor Problems (http://forums.pelicanparts.com/off-topic-discussions/247281-neighbor-problems.html)
Milu 10-24-2005 12:27 PM
Originally posted by Jeff Higgins
I'll post some pics when I get home. Pretty simple really. Any Harley shop has, or can order, drag pipe baffles in 1 3/4" or 2" diameter. If you are lucky enough that your sport muffler outlets have either dimension for their inside diameter, you're in business.
Mine has a 3" diameter! Custom fabrication coming up I suppose.:confused:
http://forums.pelicanparts.com/uploa...1130181931.jpg
What I found softened the sound and made mine less offensive (to my ear as well) was running on Shell V-power fuel (high octane). It might be worth trying.
WolfeMacleod 10-24-2005 02:22 PM
So I wonder if it has the same tonal quality at idle and just off idle as it does when screaming down the track like you heard it.
If you want, you can bring it over and I'll take a listen to it, since I didn't get to hear your car at idle. I didn't realize you're so close to me. I'm on 143rd and Greenwood, north Seattle. SmileWavy
Intruments builders literally tune instrument resonance by removing wood in various places....bracing, top or back wood, etc. I'm positive this could be applied to an exhaust system. It could be as simple as increasing the size of your pipes, changing a bend, or adding a brace to a pipe somewhere.
Drago 10-24-2005 02:41 PM
I like Sup's idea. Single-in/dual-out Dansk w/ a test pipe. I'll bring the beer.
Jeff Higgins 10-24-2005 04:53 PM
Here are the pics of the drag pipe baffles. Doesn't look like it would work for you, Milu. The outlets need to be straight. Anyway, all I do is slide them in and put one sheet metal screw in from the bottom to keep them from popping out. I just grab one of the inner triangle shaped flanges with a pair of needle nose to pull them out.
http://forums.pelicanparts.com/uploa...1130197824.jpg
http://forums.pelicanparts.com/uploa...1130197882.jpg
Intiguing thoughts on "tuning" the resonance out of my exhaust system, Wolfe. I would be interested to explore that. Right now, I'm already tearing it down to finish the paint before it gets too cold. When I'm done with that I'll let you know so you can take another look at that.
WolfeMacleod 10-24-2005 05:16 PM
If or when the exhaust comes out of the car, I'd like to take a look at it.
