Deep frying your Turkey: Have you done it?
Looks like I may try to deep fry a small to medium sized Turkey just to see how it turns out. I friend lent me his propane fueled setup. I'll have to look on the net for instructions as he couldn't find them. I figure there's probably a chart or formula for the temp, bird size/weight and amount of time to cook.
Here's what I know from others who have tried it: - Carry-out the operation outside away from the house, deck, garage and any flammable material. A dirt clearing in the yard? Wouldn't want to clean up pavers or asphalt. - If windy use plywood, card board or other material to shield the wind. If the burner isn't allowed to operate at full temp the going will get rough. - Test for the amount of Peanut oil required by dipping the bird in the pot of water. This will prevent under or over filling with oil when it comes time to fry. - Use a fully thawed and dry bird. Well, as dry as you can get. (I've heard some deep fry frozen turkeys but that's a bit advanced for me on a first go round) - Season the bird the night before. Let the seasoning do it's thing overnight. - When you get to proper temp, up it about 50 degrees as it will lower quite a bit when the bird is submerged. Monitor oil temp with themometer and adjust to proper temp when it comes back up. - Use of an internal therm is nice. - When done hang bird and let oil drain for 20-30 minutes. - Bird will cook quickly...dont over cook. - Be prepared for a mess.....and the best tasting Turkey ever....(We'll see) Any thoughts, corrections, additions? -
Warren & Ron, may you rest in Peace. |
Banned
That sounds right to me.
I have done this before. It WAS good but I like a turkey in the oven better. + in the oven you get that turker smell all throughout your house. The peanut oil lever is very important, if its over full it will start a large fire. |
Apron, gloves, and a face shield are useful safety measures. (Or so I've heard.)
We've grilled our turkey the last few years on charcoal. It works great but you have to have extra charcoal to keep the temps up in the grill. And it's tough to extract the juices for the gravy.
1987 325 eta |
Done this before, Turkey comes out GREAT.
1) 100% right on the water idea. Mark the level with a grease pencil or something on the outside of the pot and then fill to just below that level. Heat the oil, but in the bird and THEN top off the oil if you need to. I've seen these things overflow and it ain't pretty. 2) Try injecting the bird beforehand with your liquid seasoning of choice. I have seen good results with Cajun mixtures and Italian dressing. Happy Frying!! P.S. You'll likely NEVER go back to baking after you fry one...
Rick 1984 911 coupe |
Light,Nimble,Uncivilized
So frying a turkey on a Whistler condo wood deck while wearing shorts, barefoot and drunk would not be a good idea?
Checking the oil level is a good idea though...don't ask...I didn't do it.
Drago '69 Coupe R #464 |
Thanks for the great tips so far guys...keep em coming.
<insert witty title here>
We did it this year - bit of a PITA to clean up, but no worse than the regular cleanup. True that you don't get the smell of turkey in the house, which we missed. Absolutely make sure about your fill level - over filling can lead to spillage which can lead to a massive fire.
Couple things to prepare for - peanut oil ain't cheap - I think it was about $40 worth of oil we needed. Also, it takes longer than you'd think to boil it - I wasn't timing it, but it must've been at least 30 min. I didn't think it was really any better or worse than a regular turkey, although it was a bit dry. Nowhere near as greasy as you'd expect, though.
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
Super Moderator
Huh. I was gonna post these same questions. I thought the deep fryer made the Turkey super moist... Isnt that the deal?
If you don't overcook it it will be very very moist, much more so than you can achieve in an oven. Don't get me wrong, I love oven roasted turkey too...
Senior Member
Have as well done this and second the recomendation of injecting the bird with various spices. I like both ways and would probably do it one way one year, then another the next. Dammit, am overseas now and no frigging turkey this year. Will miss it a lot! Joe a
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
3 minutes a lbs, + extra five minutes. i back this up, with a probe thermometer. also, look up a nice turkey brine to soak the bird the night before. also, warn all those peanut allergy guys, if you use peanut oil. my boss makes me cook two, every goddamn year, for our office picnic. i did get a free fryer out of it tho.
poof! gone |
Oh speaking of thermometers, get one specifically made for deep frying. First time my father-in-law fried a turkey he put a standard kitchen thermometer in the oil (with mercury in it) and bam!! Mercury in the oil and in the turkey...run to store for another turkey...
hahahah rick! that is classic.
poof! gone |
I was going to use a type K Thermocouple to measure temp
![]() Cliff: What temp is your formula for?
opps. i keep the oil at 375. i have a fry therm in the oil and i have a probe stuck into the thick portion of the breast. i shoot for 165 there. logic being that the dark meat is near the heat source and will get closer to 180. my logic seems flawed typed out. good luck. oh, i never fry a turkey larger than 15 lbs.
poof! gone |
Detached Member
Mmmh., boiling oil, lots of young neices and nephews running around. So someone do it at the beach once, wicked dangerous.
Hugh |
For sure dangerous...I'll likely be alone and outside while others are entertained by my antics from the comfort of my sister-in-law's house.
I recall being at a party years ago where my (female) boss would use a large homemade deep fryer to make the best southern fried chicken I've ever had. It was a tall contraption perched on four iron legs. While unattended and frying a little girl (read shorter than the fryer) walked over to the fryer and started pulling on one leg. The fryer was on the driveway and on an angle/incline! I yanked the girl away before she pulled the thing over....almost shat myself on that one.
Yeah keep the kiddies away for sure. Great opportunity for the men-folk to stand around and BS in the cold though...man with fire heat oil to near burning and char bird...UGH.
coulda, woulda, shoulda
I do many each year. in the last 3 weeks I've done 7 and tomorrow I do 4-5 for friends and 3 on thursday. I bought another new electric fryer to go with my other electric one to cut my frying times down. I really like my electric fryers and don't think I'll go back to propane anytime soon. set it and forget it! that leaves much more time for drinking instead of watching the temps
John 74 911s They laugh at me because I am different. I laugh at them because they are all the same. |
