Senior Member
Post Donīt update to wife 1.0 reguarding homenetsecuritys
Software corner: Tip to wife 1.0
Monoliti Appliaktion with killer instinct
Also this Gemme of modern literature trunk unfortunately not from my own feather/spring (even if one could come easily on the thought...; -) read and erheitert you.
" last year made a friend upgrade from friend 3,0 on wife 1,0. Its experiences thereby were haarstraeubend!
This Apllikation used up extremely much workspace and leaves almost no more system resources. With more exact Hinsehen it found out then that this application calls additionally " child processes ". That entails naturally that anyway already scarce resources is still more stressed.
Additionally the application is very operating system near programmed. It latches itself equal with boats into the command structure and controls thus all resources. That can be done have to inquire so far, other applications with it and then if necessary. get simply no more resources assigned. Thus some applications are no longer executable after the installation of wife 1,0. In addition belong e.g.. Skatabend 7,1, Extrembesaufen 3,4 or tavern route 5.0.
To all abundance the system seems to suffer from day to day more from these circumstances It looks in such a way, as if wife 1,0 would widen herself like a virus in the system. Logs are made over all internal messages of other processes.
Others with the application user trusted had beforehand warned it, but since none of these phenomena in the product description or guidance were mentioned, it had probably simply ignored this
A further point of minus for this Appliaktion is that it does not offer any options with the installation. So one cannot decide whether addition products are to be installed such as mother-in-law 1,0 or brother-in-law 1,2 with.
One has to build some important features even simply forgotten into the application. There would be e.g. more uninstaller, " never remind me wieder" Button, a minimize Buttom or the support of multitasking, so that at the same time still different programs have chance to communicate with the system.
Personally I, I think with friend 5,0 will remain, although the also not even is uncomplicated. Like that it was possible e.g. with no version to install it simply in such a way over EN predecessor No, beforehand a clean Deinstallation had to be duchgefuehrt, in order to guarantee that no more INTERRUPTS are blocked or I/O port. If one should forget this, then it can occur that those freshly falls simply in such a way installierteApllikation. Then nothing differently more mostly remains to procure itself than new copy. On provided university stable one should not have however under any circumstances relied. Almost grunsaetzlich any remainders in the system remain.
A further problem, which most versions of friend have, is the annoying request nevertheless to procure itself upgrade on wife 1,0. This appears, as with all shareware programs, in regular intervals, but usually if one can use it to few."
" hello,
I can acknowledge the experiences, the problem however as follows solved:
Delete 1,0 into EHEFRAU.ini all entries after installation of wife, whom with " I want to begin... ". Subsequently, rename the assigned work area of GLOBAL in LOCAL ONE.
In the assigned (now local) work area different time-consuming processes install, e.g. rinses, flash etc. (with it better older versions use, those are slow and memory-intensive).
After that boats is now almost exclusively busy the program wife 1,0 to process the processes in the assigned work area. The total system becomes somewhat slower thereby, but resources to have with me, become free now, equipped-calibrate to install around a new version from friend to."
http://translate.google.com/translate?hl=en&sl=de&u=http://www.rzuser.uni-heidelberg.de/~cdoerr/hausfrau.html&prev=/search%3Fq%3DMonolitische%2BApplikation%2Bmit%2BKi llerinstinkt%2 B%26start%3D60%26num%3D30%26hl%3Den%26lr%3Dlang_en %7Clang_de%26safe%3Doff%26sa%3DN
Something gets lost in the translation but itīs still hiting.
Grüsse
Old 07-22-2001, 05:14 PM
Blackfoot's Avatar
Post
i was running gf 4.0, but found after a while it also took too many rescources. i deleted & rebooted, and now all is fine. i now have more rescources for my 951 2.0, also.
Old 07-23-2001, 03:20 PM
