Help! Leak around door frame
It has been raining for a couple of weeks here in Seattle and i discovered a leak around a sliding door frame. Slow consistent leak.
Any thoughts on what the cause is and how to fix it? Or even who to call to come take a look...2 storey house, door is on first floor. Leak is a slow drip on the side of the frame. House is about 6 years old.
88 Carrera Coupe Pelican Since 2002 All Zing, No Bling. ok, maybe a little bling. The Roach |
Hell Belcho
silicone caulk is your friend
Saved by the buoyancy of citrus. |
Well the "cause" is a hole or crack that is allowing the water in. Now the hard part is finding it and there may be more than one. The first thing to do is a good visual inspection to see if you see anything obvious. If you find it then silicone caulk is some of the best stuff going as it adheres well and remains flexible but be aware not all silicone caulk is paintable which may not be important to you. If you can't find it visually then try having someone spray on the outside with a garden hose as you watch for leaks. Good luck.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Who is John Galt?
Take care of this quickly, or you WILL have rot. Sliding doors are notorious for rotting floors.
Check along the top of the frame, on the outside. It should be flashed, but may not be.
'79 911sc Targa '02 slk230 kompressor '84 Tamiya Falcon A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years. |
