Re: Attic pull down staircase question.
We're having attic trusses designed, so we can replace some of the W style trusses to open up storage space that is now wasted. I expect we'll add about 800 square feet or more space to the house for storage of things you don't want ready access to, but don't want in a garage environment either. |
When you say scissor brace are you meaning manufactured trusses? If you are, they need to be designed and ordered specifcally for attic storage...most homes are not.
Most are built to support your roof not hold weight across the bottom of them for storage. |
We expect to gain stand up height attic space at least ten feet wide, knee wall space 5-6 feet wider, and something like 55-60 feet long. That's only changing part of the trusses out. |
I was replying to Moses, since it was his thread.
I installed the Werner tall aluminum pull down ladder. It is installed correctly, however it fails to close snug against the ceiling. This is where its spring mechanism is at its "least sprung" tension. I have been unable to find a workaround for it.
http://forums.pelicanparts.com/uploa...1139247445.gif |
This happens whe the installation is not 100% plumb and square. You may want to double check the install. |
You can do quite a bit in a day. |
Let's see, http://www.ultimategarage.com/dynapack996tt-d.jpg Yes, it works for now. If it breaks, here's the url: http://www.ultimategarage.com/dynapack996tt-d.jpg |
Moses - why not bury the lift in the floor - or have a pit?
| All times are GMT -8. The time now is 06:36 PM. |
