Towing
I'm headed down to Tennessee next month to start cleaning out my father's storage space. It appears the most economical way to move stuff from Tennessee to my house is going to be to pull a trailer with my F150.
I have the 4.2 V6, and it has a factory towing package. There is the flat four-pronged connector for the lights and a round connector that I assume is for trailer brakes. I've pulled a trailer once in my life, and it was a 400 lb. painting trailer when I was a house painter in college. I'm looking at renting the following trailer: http://www.uhaul.com/guide/?equipment=trailer6x12 This trailer has a maximum loaded weight of 4400 lbs., and if I read my owner's manual correctly, my truck can tow up to 4500 lbs. My questions are: What equipment do I need? All I can think of is a hitch ball, a ball mount, and chains. How do I determine what size drop I need on the ball mount? Any hints, tips, recommendations? |
UHaul can be picky about what they allow you to tow their trailers wiht. I've read on 356talk that several times people were forced to rent a uhaul truck to tow a uhaul trailer.
I was going to swing by a U-Haul this weekend (I'm not going down to Tennesse until the middle of March) to see if I could sort that all out ahead of time. I haven't thrown out the idea of buying a trailer, but it would be significantly cheaper to rent.
U-Haul is actually the best place to have a trailer hitch installed. I know you already have one, but go to them, and let them finish what you have. That way you know there wiill be no problems come rental time. Find one of the centers that does the hitch installs, not the storefront / service station place.
The U-Haul place should be able to give you the information you need. That trailer looks like it has a low to medium height coupler, so I'm guessing you will probably need a drop of 1-2", assuming you have a 2WD F150.
Legion, you will have no problem at all towing that.
You'll need some facitlity for braking. I wouldn't want to haul that thing down in a hurry without trailer brakes! Electronic brakes will require a brake controller box installed. $55 plus installation cost.
Do hydraulic surge brakes require a brake controller, though? I have no idea. I just run electric drum brakes.
How many pounds of cargo, legion? |
U haul trailer all have surge brakes
i am a ******* when it comes to towing. i almost died once. (now i am a big fan of overkill.) if i had to do what you need to do, i would call penske and rent a moving van. i bet the cost arent that high when you consider, how much easier it will be. no backing up a trailer for a newb, less wear and tear on your 6 banger, etc.
having said that, i do see some people doing some amazing towing with what i consider a small truck. good luck. |
Re: Towing
Per the Uhal site: Your towing vehicle: * Must be equipped with a hard top if it is an SUV. U-Haul does not allow any type of sport-utility vehicle not equipped with a hard top to tow U-Haul equipment. * Must weigh at least 3,500 lbs. (curb weight) * Must have Class 2 tow hitch (3,500 lb. minimum weight-carrying rating) * Must have 1-7/8", 2" or 2-1/8" hitch ball (3,500 lbs. minimum) * Must not exceed maximum allowable hitch ball height 25" * Must have external mirrors on both sides * Must have fully operational lighting * Trailer lighting must be operational at all times, day and night * Maximum recommended speed is 45 MPH Correct on the round plug as the electronic brake controller. However, Ford did not supply the electronic controler in the vehecile until 2004/05. You need to purchase one. It plugs in under the dash on the driver's side. You will have no probelm towing with the 6 banger. Although I have the 5.4l, I've towed 40' trailers with my F150, lifted, 35" tires and stock gears. That';s the same trailer I have reserved for my move to Florida, but I changed out the R&P for the long drive. Good luck. |
Thanks for the replies everyone!
I just read the whole Uhaul flyer. It says repeatedly that I should not exceed 45 mph when towing even the heavy 6' x 12' dual-axle trailer.
It takes 7 hours to drive from Nashville to here doing 70 mph. I was thinking that 60-65 would be safe trailer speeds until I read that. Is that statement extreme over-caution, or should I really do 45 mph the whole way on the interstate, making the trip take 11 hours? Heck, I've been passed by people towing trailers doing 85-90 mph. |
I routinely tow my 32' 10,000 boat at 75mph but I also have my trailer balanced perfectly. And my truck is heavy.
There are alot of variables to consider when towing. The weight placement on your trailer, brakes on it, brakes on your tow vehicle, weight of tow vehicle, experience, etc.... It's real easy to have a trailer go out of control on you. Ive towed the boat with my Bronco, and my old f150 ( Very, very short moves) both have electric brake set up, but it still was a ***** to stop. 6x12 is not a huge trailer, it just takes loading it properly and getting the feel of it. |
I towed that trailer from CA to MI with my Subaru Outback Sport, trailer was as long as my entire car. You'll be fine.
Legion,
I have no trouble with my 4.2 5-speed pulling my wife's horses. Up over the mountain is usually 3 rd gear for the most part and, with the horses we usually don't get over 55mph. (don't want to have to brake suddenly & break legs or anything.) If you have the factory 'trailer wiring' package, it is likely you also have a transmission oil cooler. "There is the flat four-pronged connector for the lights and a round connector that I assume is for trailer brakes." You might have two kinds of connectors, there. One the flat 4-pin, for small trailers with no brakes, the other round with 6 or 7 pins for larger trailers with brakes. The hitch place can straighten you out on them. Make sure you have about 500 lbs of the weight on the tongue when you are towing. You should get along OK. Now, backing up should be fun the first time you try. Can I come & watch? (Sorry, that wasn't nice. Sorry you have to make this trip.) Good luck. Les |
In my view, driving the speed limit is okay, as long as you keep WELL BACK from the vehicles in front of you, take due caution of weather conditions, and are always aware of traffic entering the roadway you are on.
You stopping AND manuevering ability will be much worse than you are accustomed to. Don't ask me how I know...;) |
On recent cross-country drives I have seen 2 different accidents where someone was towing a large trailer and it whipped or rolled on them, taking the tow vehicle in a barrel roll with it. One of the cases might have involved strong cross winds, not sure. Both tow vehicles were large GM pickup trucks, (one was a Suburban), I can just imagine how terrifying that experience must have been. Shorts cleaning time.
Both were on the interstate and the people towing were amateurs, (like me), it really gave me pause. Be careful and take your time. :cool: |
Does nayone know is a LEO would, or could, cite you for driving over the 45 mph marked on the trailer?
| All times are GMT -8. The time now is 10:08 PM. |
