-   -   Octane booster in a bottle does it work? (http://forums.pelicanparts.com/off-topic-discussions/271998-octane-booster-bottle-does-work.html)
Jims5543 03-17-2006 05:30 AM
I am asking the Pelican brain trust, does it work?
VINMAN 03-17-2006 05:41 AM
Think its a load of crap.
Jeff Higgins 03-17-2006 06:09 AM
How could you tell if it does? I have often wondered that. If there is more power to be had, it can't be much. If you can advance the timing more before it starts to ping, again, it can't be much. I run mine fairly conservatively as it is. I'm curious too...
Jims5543 03-17-2006 07:10 AM
I am running a DE this weekend and have 6 gallons of 100 octane on hand. I usually mix it 50/50 with 93 and make some 96 out of it.
I am not running it for more power, I am running it for safety for my engine. This is for my RX-7 and I like to use the higher octane to reduce the chance of detonation when things heat up.
Worse case scenerio I buy my gas at the track for an inflated price. :(
widebody911 03-17-2006 07:30 AM
In order to be able to take advantage of higher octane, you have to have a computer controlled engine or an engine built for it. Extreme example: I could put avgas in my VW bus, and it wouldn't make one bit of difference with my 7:1 compression.
I run 100 in my 3.6L for track events, and it's happier that way. I can feel the difference between 100 and 91 consumer-grade pump gas.
The stuff sold at auto parts stores is complete crap; you'd be better off spending that 10-spot on a bottle of Techron.
If you're looking for an over-the-counter octane booster, a gallon of toluene or xylene (found in the paint aisle at your hardware store) would be more effective and more economical.
sammyg2 03-17-2006 07:38 AM
Octane booster in a bottle is basically snake oil.
When they claim it raises the octane by up to 4 points, that does not mean it will go from 91 to 95, it means it "might" go from 91 to 91.4
Not worth the money IMO.
VINMAN 03-17-2006 07:42 AM
I run 102 in my boat( my motors are 12.5:1 compression)
I've ran 105 and higher. and really had no increase in performance.
Rodeo 03-17-2006 07:46 AM
Isn't octane just a detonation inhibitor? I thought the only thing octane did was make the flash point higher so high compression cars did not suffer from pre-ignition.
Is that too simplistic?
Jims5543 03-17-2006 08:36 AM
Yup, thats what I need it for. My car runs fine on 93 and it is tuned for 93 I just like the extra insurance of the higher octane, especially when she heats up on the track I see 230° water temps when on the track for 30 minutes.
Jims5543 03-17-2006 08:37 AM
BTW - Holy Ferrari!! I just checked the track roster and there is goinf to be over 8 Ferrari 360's there. This should make for either a really fun day or a really dangerous one.
slakjaw 03-17-2006 10:16 AM
If you are planning on getting gas in mexico you should take some with you. It did help stop pinging on mexican petro
Porsche-O-Phile 03-17-2006 11:42 AM
In a word, no.
Get Xylene or Toluene for real effect. Also check this:
http://members.rennlist.com/951_racerx/ (the "Octane" stuff)
Jared at Pelican Parts 03-17-2006 12:04 PM
Simple answer, no.
You're better off buying either racing fuel or if you have access to it, and no catalytic converter, aviation fuel
yellowline 03-17-2006 12:11 PM
They even have the stones to say that on the bottle in fine print!
