-   -   Basic basic electrical question (Ohm's law) (http://forums.pelicanparts.com/off-topic-discussions/274789-basic-basic-electrical-question-ohms-law.html)
cowtown 04-01-2006 02:31 PM
What am I doing wrong here guys-
I have a tiny auto light bulb and want to know its wattage so I can go shopping.
It draws 120mA as measured by an in-serries ammeter at 12VDC. Ohms law says that means it is approx. a 1.44 watt bulb and its resistance is 100ohms.
But measured filiment resistance is 9.5 ohms...huh? What's wrong here?
slakjaw 04-01-2006 03:00 PM
Try a diffrent DVOM.
Thats all I can think of.
red-beard 04-01-2006 03:55 PM
As the wire heats and glows, the resistence goes up.
slakjaw 04-01-2006 05:24 PM
Oh yeah thats right. I forgot about that.
cowtown 04-01-2006 05:40 PM
Red-beard -so it's normal that cold resistance would be that low and the 1.44W calc is OK? Thanks.
fastpat 04-01-2006 05:43 PM
Re: Basic basic electrical question (Ohm's law)
What does the manual call for in the position the bulb goes in? You're not working on a car without a maintenance manual open are you?
slakjaw 04-01-2006 05:49 PM
http://www.geocities.com/SiliconValley/Circuit/1858/resiscale.htm
Yes it is normal.
I used to know that, but I never need to use some of that knowlege anymore. so you know, it gets forgotten.
red-beard 04-01-2006 05:58 PM
The nominal wattage may be 2 watts. Where is the bulb located? The speedo/guage cluster?
red-beard 04-01-2006 06:00 PM
Also remember, car are 12v nominal, 13.8V at the battery and about 15vdc when charging.
cowtown 04-01-2006 06:08 PM
It's a bulb from the 3rd brake light array on my 993. It's a little one, and there are 20-something of them.
