Evil e30 update: Muwwaahhhhaahh
Well the motor is together and ready to drop in. My digi cam took a crap so I couldnt take any pics of the build up but it done. Here are the specs:
Stock block rebuild. 7.5:1 compression. Metric Mechanic head w/ 288 shrick cam Metric Mechanic Head Bolts Stock head gasket (for now) Here is the original test fit to make sure the mounts worked with the 318i locations: Then I pulled it back out and put the head on: I also POR-15 the engine bay with some gloss black. Came out really well. Here it is all ready to drop in: And a little german love: I'm should be getting a set of solid motor mounts in the next day or 2. For now I'm going to use new rubber mounts. This weekend I'll be mounting the accesories, EDIS system, and start with the MegaSquirt wiring. Flywheel is off for lighting today hopefully. |
I am definitely watching with interest! Good work
1975 911S (in bits) 1969 911T (goes, but need fettling) 1973 BMW 2002tii (in bits, now with turbo) |
Dept store Quartermaster
Looks good, but I forget, are you doing a turbo on this as well?
Cornpoppin' Pony Soldier |
Yes sir re bob. Think about going with a Holset HX50.
The engine management will be handled by MegaSquirt for fuel and spark. I am install a EDIS-6 system. On a bad note, the engine was knocked off the stand last night. . But luckly it only damaged the VR sensor bracket I made and the A/C bracket. It could have been alot worse.
Nice project
My brother did this a few years ago 89 e30 with a 3.5 stock 8.5 compression perfect for a turbo... later he put a Turbo on it . Car was very fun until he wrecked it . Car did not like high speed highway driving at all in the rain. Know he is building a 76 2002 with a turbo M20 and he is also using a holset. |
Banned
I'm with Bill
Sorry about the drop dude.
Keep us posted on your progress it sounds like your well on your way now. A lot of Rotary guys are using Corvette ignitions when switching to stand alone. The ignitor and coil are intigrated and compact.
1978 Mini Cooper Pickup 1991 BMW 318i M50 2.8 swap 2005 Mini Cooper S 2014 BMW i3 Giga World - For sale in late March |
I think the GM system is similar setup to the Ford EDIS system I'm using. Basic wasetd spark system. Yep john, its virtually the same as the 745i turbo motor except it doesn't have oil squiters in the block. |
I FINALLY got that bad boy in there. No major issues with the drop. There are 2 positions (holes) on the e30de motor mounts I'm using. One moves the motor 1" forward and vice versa. Ended up using the most reward position because I could fit a radiator in there.
The only other clearance issues are with the VR sensor for the EDIS system. It barely touches the radiator. Looks like I need to make a 3rd bracket, lol. Or atleast modify the one I just made. Here are the pics: ![]() ![]()
Banned
The crank position sensor from a M30B35 engine (1989-1992) wouldn't fit, or function correctly? I have one that I could photograph for you tomorrow if need be.
I just remembered, I have this photo of the crank position sensor: ![]() Note that the toothed portion of the crank pulley is behind the pulleys. Last edited by fastpat; 06-12-2006 at 04:53 PM.. |
Supposesdly there are issues with MegaSquirt using a 60-1 wheel. I haven't seen one running correctly but have heard stories which add up to nada. So it was eaiser to just weld the wheel on and go.
