-   -   Cleaning/painting ABS sensor rings... (http://forums.pelicanparts.com/off-topic-discussions/298323-cleaning-painting-abs-sensor-rings.html)
Don Ro 08-12-2006 07:44 AM
Group wisdom,
'Going to put a used set of ABS sensor rings on some new lightweight motorcycle wheels.
I know, sounds goofy adding more wt. to a lightweight wheel.
The entire ABS system will be yanked one day (including rings).
I'm going to clean/de-rust them and wanted to paint them.
I know ABS ring splines and sensor are a magnetic deal...any worry about using gloss paint on the rings or should I use a flat paint?
Any advice/thoughts are greatly appreciated. Thanks.
SmileWavy
