-   -   Digital Camera Help (http://forums.pelicanparts.com/off-topic-discussions/303550-digital-camera-help.html)
Howard Agency 09-10-2006 07:32 AM
Digital Camera Help
All of a sudden, Windows XP doesn't recognize my Olympus IR 300 camera. Always did before, and auto ran camera and scanner wizard.
Still sees it, but only as a removeable storage device. WTF did I do now?
stevej37 09-10-2006 08:07 AM
Maybe not as simple as this, but mine does the same thing..unless I make sure I turn the camera on after hooking it up. If I turn it on before hooking it up, it won't recognize it. Hope this helps.
charleskieffner 09-10-2006 08:11 AM
howard clear your screen so only icons appear. plug camera in. turn camera on. puter should start making noise(scary) and wa-la screen should pop up showing pics being downloaded. make sure camera batteries are new or charged fully. hope that helps.
Howard Agency 09-10-2006 09:12 AM
Interesting. Two choices on the camera screen when attached to USB, 'PC' or 'Print'. Select PC=Storage device, select 'Print' and wizard starts. When using print, I can't delete pix from camera (with windows).
Plug and Pray. Thanks guys.
john70t 09-10-2006 09:15 AM
Double check control panel/system/device manager for the device also(?). Nothing should have changed it as default.
charleskieffner 09-10-2006 09:21 AM
since i have a 2 story house and a pool below......................at this point, my camera and computer would be sailing over upstairs wall into the ...................ABYSS! kersplash!
has anyone been on your computer since the last time you were on? my kids USED to crash me all the time. now NOBODY screws w/my puter................nobody!
i found that going direct off of my camera vs card reader always worked. card reader was finicky. it was a 6 in 1 reader..................kersplash!
Hugh R 09-10-2006 03:42 PM
No solution to why it happened, but right click on "Start" and use explore to see if you can find the external drive (E) usuallly and see if you can open your pics and copy to your hard drive.
