Bent valve, is it worth it to fix..........
My lawn mower? :D
I've been struggling with my lawn mower for a couple of weeks now. Cleaned the carb, checked for spark, even checked to make sure the flywheel didn't break the locater key and spin on the shaft. All checked out, but still, no start. Tonight I pulled the valve cover off and found a dropped exhaust valve. It won't pull out of the guide, so I'm assuming it's bent. Did a search, and the parts are going to cost ~$30 or so. After that, I figure it'll only cost me my time, and my time is free when I'm fixing something for myself, to paraphrase Peter Egan. Plus, I kind of enjoy this stuff. :rolleyes: Is anyone else here cheap enough to do a top end rebuild on a lawn mower that was bought used at a yard sale for less than $75? (BTW, an equivalent mower (6.5HP, RWD, mulch/bag/side discharge) would probably cost $300-400.) Maybe I should just hire a gardener. Jim |
Hire a gardener and spend the free time working on the PORSCHE
Fix it. Time for a performance cam. If it's not OHC then make it OHC.
Perhaps some forced induction while you're at it. Heck, if something breaks then take the chance to upgrade! Sodium filled valve, a small turbocharger..... You would have the coolest lawnmower on the block. On a related topic, I'm just as cheap. Have you ever bought a matching set of broken end tables just to cannibalize one to feed the other?.... |
I would pull the valve out, take a hammer to it until its straight. Then reinstall and see if she fires up. Cost $0. Its just a lawn mower. Wouldn't try this on the 911 though.;)
Try it. If it works, focus on the important things - like forced induction turbocharging.
I've fixed Briggs motors with a hammer. Just try to get the valve as straight as possible. If it doesnt work, who cares?
Yup, I'm an idiot with no life. Pulled the head off tonight (~30 minutes, two beers), and it looks like the valve isn't bent, just really gummed up with crap. The weak little valve spring simply didn't have enough force to pull the valve back up.
Tomorrow I'll ream out the guide, polish both valves, and I should be good to go. Since I'm not a fan of forced induction, I think I'll limit mods to an early S cam, a bump in compression, and maybe an M&K muffler, if he'll make me one. I'll probably skip the cad plating of bolts and powder coating of engine tin, at least this time. I wonder what it would take to put MFI on this thing. :D Jim |
I once ported out the head on a 5HP Briggs in a homebuilt go-cart cause I was bored. I have no life as well
MFI? It's got more than one cylinder?
Use alchohol instead of gas. |
while your in there: rejet the carb
lighten the blade for more rpms port and polish ever see Tim the toolman's lawnmower? it was a serious yard tool. |
plant a dezert xeriscape, never water it, never mow it, never touch it...........and watch it grow.
| All times are GMT -8. The time now is 04:34 PM. |
