-   -   Please explain a dry vs. wet motorcycle clutch. (http://forums.pelicanparts.com/off-topic-discussions/312807-please-explain-dry-vs-wet-motorcycle-clutch.html)
Rick Lee 11-02-2006 07:52 AM
Last bike I rode was a dual sport Suzuki something or other with a wet clutch. Our class instructor said most bikes have "wet" clutches which are constantly bathed in oil and so you won't wear them out by using the friction zone in stop and go traffic or at red lights or on hills. But the 2004 BMW R1150R I'm picking up this weekend has a dry clutch. I understand car clutches pretty well and only ever use them for shifting, not inching back and forth on hills or in traffic. How do I not beat up a dry clutch on a bike? Or do I have nothing to worry about?
speeder 11-02-2006 08:00 AM
I've never exactly understood how wet MC clutches hook-up, but BMWs have always had relatively huge dry clutches that look like they belong on a small car. I know that BMW clutches last a long time, but then I don't recall ever having to do a clutch on any MC.
Bill Verburg 11-02-2006 08:06 AM
It's common practice on m/cs to have the clutch and trans gears together in side the trans case bathed in the same fluid. They will use multiple plates that are designed to work in that environment.
On most cars the trans case is separate from the clutch aka dry.
Nostril Cheese 11-02-2006 08:19 AM
most bikes use a series of clutch plates in a holder. In some ways it's better than the clutch on a car. Compact, easy to replace.
BlueSkyJaunte 11-02-2006 08:19 AM
One sounds like a tin can full of marbles, the other doesn't. ;)
928ram 11-02-2006 08:29 AM
I'd say nothing to worry about, whichever system is installed on a particular bike is sized and engineered for a reasonable lifetime of normal use.
Porsche-O-Phile 11-02-2006 08:31 AM
If a wet clutch system is so much better and lasts longer, why not use it on cars? Too much fluid (weight) or what?
Joeaksa 11-02-2006 08:39 AM
The clutch on the R1100/R1150 lasts a long time when taken care of. Have owned two of them and no problems there.
Do not sit at a light with it in gear and the clutch pulled in. The throwout bearings are not the best in the world and this puts a lot of stress on them, so keep it in neutral until ready to go...
Nice bikes, I miss mine!
Rick Lee 11-02-2006 08:49 AM
Joe, is 12k miles high for this clutch? Owner has been meticulous with all maint. too.
nostatic 11-02-2006 08:52 AM
that's a feature, not a bug :p
Somewhere a Ducatista is signalling "fangul" in your general direction.
MotoSook 11-02-2006 09:04 AM
You get the funniest looks from drivers when parked next to them at a light while riding a bike with a dry clutch (marble in the engine sound).
I don't see why anyone would need to use the clutch to hold the bike from rolling back on a hill or use the clutch otherwise for anything but to accelerate from a stop or to change gears. The rear brake is separate from the front. Even on a hill once can balance the bike with the left foot on the ground and the right foot on the rear brake, releasing as the clutch comes out when starting off.
Bleu: fangul! ;)
Porsche-O-Phile 11-02-2006 09:10 AM
I usually keep it in neutral until I'm ready to roll but to be fair I have no idea which kind of clutch my bike has. I'm assuming a wet type, but honestly don't know.
Doesn't sounds like it 's full of marbles either.
SlowToady 11-02-2006 09:22 AM
My dad has a K1200LT that also has a dry clutch, and he has over 30,000 miles on it. He's never said a word about the clutch.
He also had a slightly older K1200LT with about the same mileage and no problems.
12,000 miles on a BMW really isn't much, you should be fine. Enjoy!
Flatbutt1 11-02-2006 09:23 AM
No, not at all. I had 29K on mine when I went in to service the tranny splines andit still had life in it.
cstreit 11-02-2006 09:28 AM
My Ducati not only has a dry clutch, but a vented cover as well. I loved the comments from people that it sounded like the bike was gonna blow any sec...
A little touchier than a wet clutch, but other than that, basically transparent. I think the motorcycle dry-clutch got it's start in racing...
VaSteve 11-02-2006 09:31 AM
Rick, you will find your BMW bike experience to be fairly similar to the 911 experience. They last forever. BMW's are meant to ride, and the owners generally have a LOT of miles on them. I have seen bikes with 100K!
I think you have nothing to worry about. Then again, if you do, there's plenty of folks around here that know how to fix stuff. We'll have to ride up to SP next time Nate Kern is racing. He's a BMW racer, races both an R and a K bike (I think). There's some cool photos in the R1100 section on this board.
motion 11-02-2006 09:32 AM
I had no idea my BMW had a dry clutch!!!
The Ducati dry clutch sound makes me weak in the knees... my Yamaha TZ250 is dry clutch also. 99% of the bikes out there are wet clutches (boring).
BlueSkyJaunte 11-02-2006 09:34 AM
Hey Duc guys, lighten up, you should hear my neighbor's POS "Iron Horse" HD chopper wanna-be. His dry clutch sounds like a major chain tensioner failure in a 911.
nosmo_king 11-02-2006 09:39 AM
Box o' rocks? That's what my R1100S sounds like- though ATGATT (all the gear all the time) includes custom ear plugs, so the sounds a bit more tolerable :D
Call me paranoid (or clueless or ... whatever) but I keep the bike in first gear and pointed towards an "exit" when I'm stopped at a light or in traffic. And always w/ an eye scanning rearwards for those crazy P- drivers (kidding) who may not "see" me or stop in time. The clutch may get toasted sooner but, hey, it's good for me!
SmileWavy
island_dude 11-02-2006 10:06 AM
12K miles on a beemer is just breaking in. This is particularly true with the earlier ones. I spend a lot of time in traffic, so I just assume that I am going to toast my clutch sooner than normal. I have already resigned myself to an early throw bearing replacement for the same reason.
There is nothing wrong with a dry clutch.
Steve Carlton 11-02-2006 10:13 AM
You can expect somewhere in the neighborhood of 60,000 miles out of your clutch, perhaps many more if you're on the freeway a lot. Strictly speaking, it's safer to have the transmission in 1st geart and the clutch in at stops in case you need to move quickly. Supposedly this won't cause premature failure of the throwout bearing on the BMW.
Are you going to take the MSF class? HIGHLY recommend it, and later on the advanced class.
greglepore 11-02-2006 10:33 AM
Some Duc guys I know have "Loud clutches save lives" t-shirts.
Joeaksa 11-02-2006 01:42 PM
Rick,
Like others have mentioned, 12k is barely broken in for a BMW bike. I have about 200,000 miles on BMW bikes and they are designed to last forever, especially if taken care of.
If you do a fair amount of highway riding (40-50%) then yours should last over 50k minimum.
Biggest thing for me is to get the service records and make sure that its been taken care of properly. You know that there is a BMW bike forum here at Pelican? I would frequent it and the only dealer in your area is Bob's BMW just outside of DC. Well known and a dealer for years.
Joe
tswaney 11-02-2006 03:37 PM
The Yamaha XS750SF triple that I used to own was a wet clutch. If I remember correctly, some of the newer motor oils were not recommended due to some of the additives allowing slippage.
Rick Lee 11-02-2006 04:20 PM
[i]
Are you going to take the MSF class? HIGHLY recommend it, and later on the advanced class. [/B]
Yes, I did it last weekend and found it almost frighteningly too easy.
Joe, I went to Bob's on Monday. I can see myself spending a lot of time and money there eventually. Now I'm busy assembling the proper gear for my cold ride home from NJ this weekend.
VaSteve 11-02-2006 06:59 PM
Joe
There's actually 2 others. Battley's is a multi-line dealer in Gaithersburg(?) Morton's is in Fredricksburg, a little closer to Rick.
Rick Lee 11-02-2006 07:02 PM
Went to BAttley's and it was lame.
VaSteve 11-02-2006 07:11 PM
Yeah, that's what I have heard. Last time I was at Morton's it was Octoberfest so it was a zoo. I'm looking forward to my trip tommorow.
island_dude 11-02-2006 07:19 PM
I haven't been to Morton's, but I have heard really great things. I don't like the set up at Battley's, but he is a good guy. The BMW salesman there, Paul is great. 75+ and gets in more miles that most. Bob's is where I spend most of my money. The staff is good and Bob is a great guy. I have had mixed luck in the service department. They have always made good, but there have been a few problems.
VaSteve 11-02-2006 07:24 PM
When I went to Bob's for my test drive, the salesman hyped up the service department. He told me that there was a film made about it by BMW themselves.
RickM 11-02-2006 07:27 PM
Here's a decent explanation from Wikipedia:
"A 'wet clutch' is immersed in a cooling lubricating fluid, which also keeps the surfaces clean and gives smoother performance and longer life. A 'dry clutch', as the name implies, is not bathed in fluid that robs it of some energy. Since the surfaces of a wet clutch can be slippery (as with a motorcycle clutch bathed in engine oil), stacking multiple clutch disks can compensate for slippage. Most Moto Guzzi and BMW motorcycles use a triple plate clutch like a car."
I recall two friends who went to a bike rally where the outside temps were very high. They came back and told me they were disaapointed that both their Bourgette "Low Blow" 6 speed boxs with dry clutchs slipped to the point of total failure. After cooling off for a while they were able to ride again but there was damage to the system. Both are avid riders with one owning an auto repair business.
I guess all systems are not created equal especially when it comes to proper ventilation.
MMARSH 11-03-2006 12:22 AM
I have 71K on my work bike. (R1150RTP) Waiting for the new 1200's now. I had the clutch done right around 67K. Considering how I ride this bike,I was pretty impressed with how long it lasted. On more then one occasion I've gotten to enjoy that awful aroma of burnt cluch. You can't slip it like we used to the old Kawis.
My Duc also has a dry clutch and vented cover. The clutch is almost as loud as the uncorked Termis.
Porsche-O-Phile 11-03-2006 04:26 AM
Coming up on 50,000 miles on my Kat - original clutch and no slippage or issues that I can tell. I've checked and I'm reasonably sure this is a wet clutch system.
Joeaksa 11-03-2006 04:36 AM
Rick,
If you are going to ride in winter, get Gore-Tex or the like. Keeps you warm and dry in the worst weather.
Also BMW has a factory heated vest that plugs into the acc. plug on the bike and will keep you toasty. I have one and love it.
Joe
Rick Lee 11-03-2006 05:06 AM
I am picking up a stellar Olympia Moto jacket today. I saw some heated chaps at the local shop and was wonderingif all modern street bikes have universal plugs for them.
VaSteve 11-03-2006 06:09 PM
Rick, if you're still around to read this, you better bundle up! My new gloves were hella nice on the way back. I hate the cold. I really hate the cold on a bike at 60mph. It's gonna suck sitting in the paddock tommorow. Have a great ride and stay safe!!
911boost 11-03-2006 08:55 PM
I know the acc pug cam standard on my GS, but we had to install one on my friend R1150R, so I would be surpirsed if his bike has one.
Rick Lee 11-04-2006 11:54 AM
Just picked up the bike and rode it about 115 miles to my folks beach house. My hands were a little cold, but that was it. I kept it under 80, but it was pretty windy out even at rest. BSiple, I installed those mirrors in the seller's garage and they were great. Thanks again! I'm kinda beat from this short ride and tomorrow's is twice as far. Thank God for heated grips.
911boost 11-04-2006 08:51 PM
No problem at all man. Ride carefully tomorrow.
Bill
