-   -   I think my laptop computer crashed- HELP! (http://forums.pelicanparts.com/off-topic-discussions/318435-i-think-my-laptop-computer-crashed-help.html)
Joeaksa 12-05-2006 07:46 AM
Kurt,
Simply take the plug in memory chips out and try to reboot it. If it boots fine (but slower with no RAM) then you can then put one of the old RAM chips back in.
Make sure you ground yourself before touching a memory chip.
joe
Rot 911 12-05-2006 09:00 AM
Originally posted by Joeaksa
Kurt,
joe
I will give that a try tonight!
SolReaver 12-05-2006 09:25 AM
Reseating the memory may work as well.
I would invest in a set of tiny tools to work on the laptop, remove the drive, back up critical data and troubleshoot per the maual.
Rot 911 12-05-2006 09:30 AM
I do have the tiny tools from working on regular PC's!
dhoward 12-11-2006 06:49 PM
So?
Rot 911 12-12-2006 06:07 PM
Originally posted by dhoward
So?
So switching out the memory didn't work. Time to take it to someone that does repairs for a living. I will let you all know what it turns out to be!
Joeaksa 12-18-2006 03:36 AM
So what happened to the laptop? Did the tech figure it out yet?
Rot 911 12-18-2006 06:44 AM
The local guy has been closed for the last few days, so no update yet!
spencejm 01-05-2007 01:18 PM
Kurt,
If you want, bring it up. That's pretty much what I do for a living. We can throw the drive into another laptop see if we can get the data off at least.
Let me know.
Joe
Joeaksa 01-06-2007 06:35 PM
Well, what's happened with it????
Rot 911 01-07-2007 10:20 AM
Wel it turns out that the video card is bad. And the video card is part of the motherboard. The computer guys for some reason only got about 1/3 of the data I have on the hard drive. None of the pictures.
Joe, I had no idea that you are a computer geek! :D Let's work out a time to get together. You can see what you can do to get the info off the hard drive and I can go over your list of things to do on the 911!
Joeaksa 01-07-2007 10:45 AM
Kurt,
I was going to SMS in Springfield in 1973 or so and trained on an old IBM 360, one of the old tube type and punch card computers. Been playing with them ever since. I fly jets for a living but putz with anything electronic in my spare time.
Now on your laptop. You should be able to plug a monitor into the back of the laptop, push the FN and either F5 or F8 key to switch the video output to the monitor. Then you can plug a USB external drive into the laptop and transfer the files you want to save there.
Alternate option is to remove the hard drive and install it into an USB external housing. Then it will plug into a USB port on any computer where you can then copy your data anywhere.
DO NOT format the hard drive or give up on your photos! I personally would remove the HD and put it in an external USB housing. Then plug it into a desktop and try to recover the lost data. I have done it before and have been anywhere from 10% to 80% successful, so its worth a try.
Will email you my direct email address. May be coming to Springfield (Brother still lives there) in the future and its not that far from Jeff City.
Joe
