jdlowery's Avatar
Photo Shop Help
Hi,
I'm not very good with Photoshop and need a little help. I'm trying to remove a skin discoloration from my son's school photo. He was holding the leash when my dog decided to run in my direction. Unfortunately, my son didn't let go the leash and ... you know the rest. I'm using Adobe Photoshop Elements and I'm trying to figure out the proper tools/sequence to complete the job. Any suggestions?
Jim
'18, Ford F-150; '07, Lexus IS350; '01, R1100S; '80, R65; '76, Honda CB750 Four; '73, Ducati 750 GT; '70, VW Beetle; '65, BMW R60/2;
'64, Triumph Bonneville; '64, MV Agusta 125 GTL; '60, BSA Gold Star; '55, R25/3
Old 12-10-2006, 02:18 PM
930addict's Avatar
Not sure about elements but in photoshop there is a tool - I believe it's called the repair tool - that lets you select a sample of the "good" image and paint it on the area of the photo that you want to fix.
Old 12-10-2006, 02:44 PM
faster than I once was...
FastDave's Avatar
Send a message via Yahoo to FastDave
I like using the tool that copies the area next to it and pastes it where u want it. u choose the area to be copied by pressing the alt key.
~Dave
Old 12-10-2006, 03:06 PM
Eric Coffey's Avatar
Ah yes, the "clone stamp" tool is your friend!
Old 12-10-2006, 04:16 PM
930addict's Avatar
I think that's the tool I'm thinking about.
Old 12-10-2006, 05:57 PM
jdlowery's Avatar
Thanks. The clone tool does help alot. My Canon printer came with some software that has a blemish removal tool. There's not much control over it but it does work well.
Jim
Old 12-10-2006, 06:01 PM
Edministrator
Steve Carlton's Avatar
After you alt-click to mark the spot you're duplicating, it'll keep duplicating from the place you started, moving along with your new copy. You need to alt-click again to start over from a different spot with your next repair. Reducing the opacity of the tool helps you blend in.
Magnifying the spot you're working on and adjusting the diameter of the clone tool helps a lot, too.
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 12-10-2006, 07:00 PM
