-   -   dell cooling question? (http://forums.pelicanparts.com/off-topic-discussions/320659-dell-cooling-question.html)
pmajka 12-18-2006 10:56 AM
working on a dell for a Friend of a Friend...
cpu (p4) fan is mounted on the back of case blowing nice cool air on the cpu Heatsink . However the 80GB sata disk is on the recieving end of the heat (this is what i need to replace).
So, should that fan be sucking the air out??? Was this installed incorrectly? Or is dell's idea of cooling the cpu and cooking the rest of the innards SOP????
id10t 12-18-2006 11:23 AM
Air flow - in the front, out the back on my systems...
masraum 12-18-2006 11:24 AM
yeah, usually the fan sucks air over the cpu from the rest of the box and then blows it out the back of the system.
pmajka 12-18-2006 12:01 PM
I concurr, the cpu fan was intalled back wards.
Wow...dont know if this box was ever serviced by someone else, but if not, What a FU from Dell. and its probably out of warranty.
just put my hand on the HD and Much cooler. Although probably too late.
SYMPTOM: from a poweroff state HD is not recognized by system...afrter a warm start (3 finger salute) HD is recognized and boots just fine.
Joeaksa 12-18-2006 08:29 PM
How long has it been running this way? Cooling air is the lifeblood of any electronic part.
If over a few months might be worth buying a second drive, installing it as the "C" drive and keeping the old drive as a slave. Try to copy any and all data to the new "C" drive and then use the computer for a month or so before trusting the old hard drive.
pmajka 12-19-2006 06:02 AM
I didnt check the GHz on the cpu, but, i figure...more than a year bast on the size of dust bunnies inside.
NICKG 12-19-2006 06:17 AM
my dell's have 2 fans......and my hard drives do get pretty hot, one failed recently
pmajka 12-19-2006 07:01 AM
so does your fan blow the hot cpu gasses at the HD?
NICKG 12-19-2006 08:05 AM
i will look tonight
