-   -   Help me solve this 3rd grade math problem (http://forums.pelicanparts.com/off-topic-discussions/324048-help-me-solve-3rd-grade-math-problem.html)
the 01-09-2007 08:04 PM
I don't know if there's an error in it, but I don't get it.
It is "Equation Building."
Student is given numbers and signs. The student is to combine the numbers and signs to get a solution that is an answer choice.
Example: 1 2 3 - x
Choices: 1; 2; 3; 4; 6
What is the answer, and why? Remember, this is a third grade level.
It seems to me there's a mistake in it, the "minus" sign should be an "equals" sign??
vangndy 01-09-2007 08:17 PM
If this is the same i used to do in school there is no equals sign given, how to do it is take the three numbers, 1, 2, 3, and arrange them in such a manner with the two operation signs, -, x, such that the solution equals on e of the options. The easy one here would be 1x3-2 the solution would be 1. there may or may not be others, i keep poking at it. also 3x1-2 but i think thats it
the 01-09-2007 08:24 PM
That makes sense, but I'm not sure there are supposed to be multiple correct answers. Here, "1" would be correct, as you've shown, but 3-1x2=4, etc.
But I think you're probably right, thanks!
vangndy 01-09-2007 08:29 PM
"3-1x2=4"
order of operations 1x2 first
3-(1x2)
3-2=1
similarly 3-2x1
still same solution (1) though
snowman 01-09-2007 08:54 PM
Total BS. I have a MSEE degree with a minor in nuk physics and this kind of problem is totally worthless, period. It teaches nothing and turns off 3rd graders and almost everyone to math. Its simply NONSENSE.
The ONLY appropriate application of this kind of problem is for some kind of game show, nothing else.
84porsche 01-09-2007 09:06 PM
I'm with vangndy - the only visible solution is 1 following order of operations. Otherwise, 4 is the other possibility if parenthesis were in the mix.
island911 01-10-2007 01:07 AM
Re: Help me solve this 3rd grade math problem
Example: 1 2 3 - x
It seems to me there's a mistake in the wording. " Example:" . . or are you saying that this is an example of the numbers and signs to be used to combine to the solutions labled "choices" ?
if so, i'm w/ the others...
3-2x1 ...gives the solution (aka equals) 1
3x1-2 = 1
3-1 = 2
2-1x3 = 3
3-1x2 = 4
3x2-1 = 5 (extra credit)
3x2 = 6
Poorly worded questions really help the teacher get a good spread in the grading. . . beyond "smart" there is the "do I give a crap" quotion -- where a certain percentage of student see the question as WTF- - next...
the 01-10-2007 08:17 AM
Re: Re: Help me solve this 3rd grade math problem
I'm not sure what it is saying, I've quoted the problem verbatim. But I think the numbers and signes are to be used to combine to the solution labeled "choices."
"Student is given numbers and signs. The student is to combine the numbers and signs to get a solution that is an answer choice.
Example: 1 2 3 - x
Choices: 1; 2; 3; 4; 6"
It's still a bit unclear to me, "1" seems to be the right answer for the reasons some have said above, but I don't think third graders necessarily know order of operation. I don't think most kids who are half way through third grade would come close to getting this correct.
Hoots 01-10-2007 08:35 AM
That one is easy to figure out. Do you have anymore?
Scott at Pelican Parts 01-10-2007 08:46 AM
All answers are correct. The important thing is to not tell the child they are wrong and therefore damage one's self-esteem ;-)
nineoneone 01-10-2007 12:44 PM
1 2 3 is 6......1+2+3=6 why would you give a 3rd grader a problem of this type anyways even if it is to use the number and signs there are too many answers.
snowman 01-10-2007 08:00 PM
Clearly to confuse them. There is no other good explanation.
esther 01-10-2007 08:49 PM
Example: 1 2 3 - x
Instructions do not state that the student must use ALL of the given numbers and signs.
At a 3rd grade level, it very well may be that this is a function of how creative the student can get with his/her combination of these numbers/signs to come up with one of the answers.
How many different ways can the student come up with the answer of 1 (etc) using any form of combination possibilities... and not necessarily using all of the numbers/signs...
That's how I would approach this if my son were given this assignment...
