white line paint on car(resubmitted)
i drove my 944 thru a construction area, and it has spray around the wheelwells from the lane change white paint.
how do you remove this stuff, it is thick! daily driver, no fancy paint, in fact it needs paint. its repainted, no clear coat, brown/purple. thanks tom
chance favors the prepared mind 1987 944 n/a 5spd. who remembers dial phones?. 'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE" |
Well, if it had been fairly well waxed before this happened, I'd say you might be able to get away with clay barring it off. If not and it is tightly adhering I'd start off with the mild white rubbing compound and if that doesn't work, go to the old fashioned hardcore red colored rubbing compound. If none of that works then you're looking at color sanding and polishing. Good luck!
Dan in Pasadena '76 911S Sahara Beige/Cork |
I would try the clar bar or some 3M adhesive remover before pulling out the rubbing compound.
David 2015 Audi S3 1988 Carrera Coupe (gone and miss her) |
i was hoping for the solvent approach. thanks
Some kid spray painted a blue streak down the side of my g/f's Lexus (white w/ clear coat) a while back. I used Goo Gone (specifically, not just any cirus cleaner) to remove it (the next day) so it's not even noticable.
The clay bar worked for me in a similar situation.
the unexamined life is not worth living, unless you are reading posts by goofballs-Socrates 88 coupe |
Custom User Title
Clay bar worked for me on some yellow road paint splatter. I used my thumbnail a bit too.
I drove over some spilled paint in my old BMW 2002, it got all over the rim and the side of the car, I used carb cleaner while the paint was still 'tacky' it worked perfect. I think there is some danger of it damaging the paint. But I rinsed it off and rewaxed the car and it was fine.
Current Drivers - 2006 BMW 1 Series & MB E320 Wagon (new addition 1998 Mazda Roadster) EX - 1993 Porsche 911 Carrera 2 EX - 1979 Porsche 911SC TARGA EX - 1976 BMW 2002 |
I would use enamel reducer. Then wash immedietely afterwards.
If that doesn't work carefully try Automotive grade Laquer thinner. s mentioned the quicker you get to it the better. Be careful as centerline paint may contain very small plastic beads to enhance reflection. Try to keep rubbing to a minimum.
Warren & Ron, may you rest in Peace. |
Hell Belcho
I've had good luck with Mother's Caranuba. The paste stuff in the red can.
Clay bars work real well too.
Saved by the buoyancy of citrus. |
