-   -   Monitor Question (http://forums.pelicanparts.com/off-topic-discussions/328099-monitor-question.html)
126coupe 02-01-2007 02:12 PM
Monitor Question
My monitor goes black, still has power, but flashes off and on.
Is it time for a new monitor???
Moneyguy1 02-01-2007 02:23 PM
Cost to replace is minimal; cost in time and effort to repair may not be worth it. Most electronics are "throwaway" nowadays. Last time I repaired anything electronic was a 10 YO Zenith TV. The only way to repair was to purchase the "module" (read entire chassis board) and replace. Gone are the days of repairable stuff.
stevepaa 02-01-2007 02:26 PM
yep, buy a flat panel one.
stomachmonkey 02-01-2007 02:32 PM
Had a bunch of 21' Radius monitors that would loose sync and go green.
Turned out the board in the back was the culprit. Two pieces of wafer about 3/4 inch apart. One side was where the cable plugged into. Cables were heavy and the stress popped the solder joints.
Was an easy fix. Bought 4 of them from the company for $50 each, fixed them all in an hour and resold for $250 a piece.
Got lucky.
Personally I'd go out and get a flat panel. They are cheap enough these days and use a lot less real estate.
I find less eye strain with them as well.
126coupe 02-01-2007 02:39 PM
It is a flat panal "View Sonic"
5-6 years old, is that a good life?
Moneyguy1 02-01-2007 02:44 PM
In a nutshell, Yes.
Chocaholic 02-01-2007 05:53 PM
You should reasonably expect 15,000 hours of use at 50% of maximum specified luminance. Do the math.
azasadny 02-02-2007 09:47 AM
Replace it, you've gotten your money's worth from that monitor. It's probably blurry and dim compared to a new one. Your eyes will thank you!
kach22i 02-02-2007 11:13 AM
My Viewsonic VPD150 is that old and still going strong. Looks like I have one more worry.
Oh but look they have a 20" one that pivots from landscape to Portrait like my old 15".
http://www.viewsonic.com.au/products/productspecs.php?id=242
stomachmonkey 02-02-2007 11:43 AM
I just picked up a nice Envision 22 for $300. CoompUSA.
