-   -   Flat Panel/Monitor Question (http://forums.pelicanparts.com/off-topic-discussions/329225-flat-panel-monitor-question.html)
126coupe 02-07-2007 02:58 PM
My 17 inch died. I just purchased a View Sonic 19 inch.
The new one has resolution of 1440x960
My pc under settings only allows me to go up to 1360x768 and the font is not very clear. I went down to 1280x960 on the pc and its much clearer.
My question is Why does my pc only go to 1360x768?
Maybe because its over 5 tears old?
slodave 02-07-2007 03:06 PM
Your video card does not support the higher resolutions. PC's are like Porsche's, upgrade one thing, you find you have to upgrade something else.
stevepaa 02-07-2007 03:07 PM
Re: Flat Panel/Monitor Question
Yeah, I cry tears too when I have to use a PC :)
probably a constraint of the memory on your video chip.
126coupe 02-07-2007 03:09 PM
so just change the video card?
stevepaa 02-07-2007 03:14 PM
If you can, but sometimes the slot for your video card may also constrain your ability to upgrade.
slodave 02-07-2007 03:14 PM
Maybe. What make/model is your PC? Your PC probably wants an AGP (type of slot card fits in) video card. Video cards now use PCI-Express and are not compatible. It may be hard to find an AGP card that will support the monitor.
Dave
126coupe 02-07-2007 03:17 PM
Dave
not sure, a custom build up from comp usa.
slodave 02-07-2007 03:22 PM
It's probably an AGP card, although sometimes video cards are incorporated onto the MB. Best bet is to find the receipt and see what it says or open it up and see if you can tell. Seems there are AGP cards that will support your resolution.
Dave
John Rogers 02-07-2007 03:27 PM
If your video is that old, how old is the rest of the hardware? If more than 2 years old then it is probably time for a complete new system and donate your old one to charity. I did that about a year ago and the ATI Rage All-In-Wonder card I have now also has HDTV outlets and a TV tuner input so I can watch Speed channel while working or run web video clips on out HDTV. My wife really hates that but they sure look better than on a small screen!
