FinallyGotOne's Avatar
Porsche Driving Tip-
One of the most critical things in driving the 911 is to NOT RUSH shifting. If you are trying to be racy and take 1st gear up past 3500 RPS then quickshift to second you are creating nmore problems than you know! our cars are fast and quick, but not meant for that kind of driving. Take your time shifting into the gears.
ALSO NEVER rest at a stop light with clutch pushed in. this creates way too much pressure on the clutch and it will wear out fast. A clutch kit costs about $475 parts.
Lastly, NEVER downshift to 1st gear. The synchros will wear out and get dogeared and cuase more problems.
Old 03-07-2007, 03:16 PM
Another mistake would be shifting at 3500 RPM in any situation. You'd be barely utilizing any of your 911's potential.
Sandy
1969 911E
1970 240Z
Old 03-07-2007, 03:49 PM
Johnb911's Avatar
What is a safe RPM to shift at?
JOHN
79 EURO SC
"24 Years Later - The Dream Came True"
Old 03-07-2007, 03:54 PM
5000 or so
Kim Langley
2012 Carrera / 991.1
80 911SC
97 C230
73 BMW 2002Tii
Old 03-07-2007, 04:02 PM
Diss Member
Quicksilver's Avatar
You can shift at 3500 but you shouldn't really lug the motor. This is way more important with an earlier car. The Motronic cars aren't as predisposed to problems from not driving the car hard so we can get away with a bit more. (but why would we want to?)
A decent rule of thumb is to not cruise at less then 3K. It doesn't hurt to at least wring it out once on each outing once it is warm. A good charge to redline will help keep the carbon deposit monster away.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 03-07-2007, 04:04 PM
It's "safe" to shift up to the redline. These cars were designed to be driven hard and wrung-out on a regular basis. Shifting at more than 2000 RPM below the redline means you're missing out on plenty of torque, acceleration and fun!
Sandy
1969 911E
1970 240Z
Old 03-07-2007, 04:06 PM
Mothy's Avatar
Send a message via AIM to Mothy
Not shifting down into first? Just did a hill climb event on the weekend and needed to shift to first many times. How do the other members handle hill climbs and motorkhana events?
Tim
Swapped my WRX Sti MY02 for a Porsche 911SC '83
Keep buying parts to make it look older.
Mid life crisis is now in its 12th year.
Old 03-07-2007, 04:08 PM
Ahh, the exuberance! Yes, all stated is correct.
87 Blk Coupe
Old 03-07-2007, 04:46 PM
Driver
Noah930's Avatar
1990 Black 964 C2 Targa
Old 03-07-2007, 04:54 PM
PorscheGuy79's Avatar
I wait for the fuel cut off to tell me to shift, thats what its there for.
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 03-07-2007, 04:56 PM
haycait911's Avatar
I figured the rev limiting rotor was a sort of ' smart' shift indicator. smarter than me anyway. Don.
Old 03-07-2007, 05:01 PM
Zeke's Avatar
Interesting. FinallyGotOne is telling us where and how to shift. OK, if you think I'm pointless here, let me make my minor correction to your thesis. Sitting at the stop light with the clutch in does NOT wear out the clutch. I'll let you figure what part does wear. But, there's a lot of life in one of those, too.
There was once upon a time when these didn't last forever and you could save some repair costs. But, today's average Miata driver will sit with the clutch in while in stop and go SoCal traffic and probably never wear it out.
Old 03-07-2007, 05:36 PM
disband
juanbenae's Avatar
wow! thank you mr. science!
Old 03-07-2007, 05:49 PM
I'm with Milt - the clutch disk is completely disengaged from both surfaces if the pedal is fully depressed and the cable properly set.
And I do not agree with both 1st gear recommendations - IMHO of course.
1972 911T/S MFI Survivor
Old 03-07-2007, 05:55 PM
Won Won is offline
Won's Avatar
Double clutch into 1st when downshifting, no problemo.
83 911SC Targa
Everything I say is my personal opinion, and has nothing to do with my team.
Old 03-07-2007, 05:56 PM
Cooper911SC's Avatar
I don't use the clutch at all when going down into first gear...the grinding noise is a good sign that you have solidly engaged the gear!
Cooper's Classy Car Care
Providing Clear Bra installation, Paint touch-up, Detailing
PCA/OCR since 1997
'81 911SC, '95 993 Tip. Project 'Euro spec' '70 914-4 w/2.0 & side shifter
Old 03-07-2007, 06:04 PM
JW Apostate
trekkor's Avatar
I shift at 7300 rpms with the motor bouncing off the limiter!
Love it!!
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 03-07-2007, 07:16 PM
Unregistered
sammyg2's Avatar
Sitting at a stop with the clutch in will put some wear on the throw out bearing, with normally only lasts about 20 or 30 years.
It will not necesarily wear out the clutch if it is adjusted even close to correctly.
Old 03-07-2007, 07:26 PM
PRO Motorsports
Tyson Schmidt's Avatar
Sitting at a stoplight with the clutch in, will put more wear on the clutch release bearing as well as the thrust bearings on the crank.
I'd be more concerned about the crank thrust bearings than the release bearing. Especially sitting in traffic on a hot day at idle with hot, thin oil and low oil pressure.
I've seen motors apart that were in the copper on the thrust surfaces of the #1 main bearing, and all else was fine. A sure indicator of a daily-driven traffic victim.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 03-07-2007, 07:31 PM
Friend of Warren
Redline.
Kurt V
Old 03-07-2007, 07:35 PM
