-   -   Help! My Desktop Computer Keeps Shutting Down (http://forums.pelicanparts.com/off-topic-discussions/344975-help-my-desktop-computer-keeps-shutting-down.html)
M.D. Holloway 05-05-2007 11:00 AM
My Wife has a Compaq Presario 6000 and it wont stay on. I unplugged it and then plugged it back in, turned it on and it sounded like it was booting up then after 2 to 3 seconds it shuts down. The green power light in the back is still on. I figuered that maybe an internal fuse went or the cooling fan has shorted out and as a predcaution the CPU powers down if their is a chance of over heating. We have had it for 4 years now.
Any ideas?
TerryH 05-05-2007 11:15 AM
Sounds like the power supply might have failed. Easy to replace. Does the exhaust fan start up with the computer?
At 4 years, it's time to think about upgrading before spending money on a relic.
HardDrive 05-05-2007 11:22 AM
+1
I wouldn't invest more than the cost of a cheap power supply, and keep your receipt to take it back if it doesn't work. You can get the data off the drive by mounting it in a new machine, or putting it in an external drive enclosure.
M.D. Holloway 05-05-2007 12:21 PM
Nope, fan doesn't start.
scottmandue 05-05-2007 12:22 PM
Check all the fans and blow out any dirt that may be blocking air flow. Like you said a lot of computers have a thermal safety shut down feature. Check any internal fans, many computers have a separate fan on the processor. I even had a computer here that was shutting down because the fan on the video card was clogged with dust.
scottmandue 05-05-2007 12:24 PM
Sound like power supply, do you know anyone with an old computer kicking around the garage you could grab the PS out of?
slodave 05-05-2007 12:53 PM
Test the power supply. Plug it in and use a volt meter to see if it is working.
Dave
