Dept store Quartermaster
lendaddy's Avatar
Unhappy Is my PC a monitor killer? New LCD going fast.
My last monitor was an old style 19" and it slowly started losing it's picture. Lots of horizontal bars, really dim, colors all wrong and out of focus. So I bought a new 19" LCD two weeks ago......but now it's doing the same thing!!!! WTF? Could my computer be doing this?
Cornpoppin' Pony Soldier
Old 05-21-2007, 07:45 AM
The Unsettler
stomachmonkey's Avatar
Anythings possible. Could be the video card. Have you tried calibrating it? Does that make a diff? Hook the new monitor up to another PC, do you get the same problem?
Is there anything in the environment that could be affecting it? IE: monitor is close to in wall electrical wiring, cord from other "dirty" signal stuff running near monitor cables? Believe it or not cell phones can affect them. I leave my cell in front of both computers in the office, no issues. The guy in the office next to mine, his Dell 19" LCD goes weird everytime my cell rings. He knows before I do that I'm getting a call.
As you know I don't keep up on viruses much but a bunch of years ago there used to be this stupid "practical joke" utility.
You'd stick it on someones computer and every time they rebooted it would shrink the display size by 1 pixel on all 4 sides.
"I want my two dollars"
"Brandon Won"
Old 05-21-2007, 08:13 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
what kind of cable are you using? The DVI's produce much better, more reliable pictures than the old VGA cables. I've had some wierd color, and focus problems with the VGA cables I'm using in conjunction with LCD monitors.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 05-21-2007, 08:17 AM
lendaddy's Avatar
I do have it hooked up via VGA, in fact this monitor only has VGA in. I will try hooking it up to another box as well.
I've also tried calibration with no luck.
Hmmm
Old 05-21-2007, 08:40 AM
Registered abUser
TerryH's Avatar
I think it's most likely the video card too. Either it's not making good contact in the slot/motherboard or it may be on its way out.
Pull the card and use a new pencil eraser to polish the contact strips. Slide it into and out of the slot in the motherboard a half dozen times. Make sure it's fully seated before tightening the screw. If the video cable to your monitor is weighing on the card, find a way to support it.
'81 911SC Coupe SOLD
Old 05-21-2007, 08:59 AM
lendaddy's Avatar
Thanks guys, it was the video card. I cleaned the connections with no improvement, but a new card did the trick. Thanks!
Old 05-21-2007, 01:22 PM
