-   -   need computer help... lost files (http://forums.pelicanparts.com/off-topic-discussions/353851-need-computer-help-lost-files.html)
notfarnow 06-25-2007 06:11 AM
Was moving pictures from one folder to another, and I got the popup "this file name already exists, would you like to replace it?".
I thought they were the same images (about 10 of them), but they weren't, just had the same names. They've now been overwritten with the new images.
PPOT brain trust: Is there any way to recover them?
id10t 06-25-2007 06:13 AM
Nope....
Joeaksa 06-25-2007 06:24 AM
Jake,
Did you "cut" them or just "copy" them from one folder to the other?
lendaddy 06-25-2007 06:25 AM
Isn't there a Windows feature that restores your whole system to a previous state?
If it's a MAC, then I think you're screwed. Perhaps either way.
notfarnow 06-25-2007 06:34 AM
Originally posted by Joeaksa
Jake,
clicked & dragged.
Lendaddy, I'll check to see if I can do a system restore.
edit: system restore has been turned off on this PC... damn
island911 06-25-2007 06:51 AM
I think that the data could still be there ... if the new file size is larger than the old, it will be written to a different spot, and the old data will just be "deleted" (where the file space is switched to be available for writing).
...but then again, it's been a while since I've recovered files.
notfarnow 06-25-2007 07:01 AM
Why only one star?!? This easily is a 4 star thread.
Shoulda known:
http://forums.pelicanparts.com/uploa...1182780335.jpg
It doesn't look like I'll recover the images. Too bad too, they were "before" pictures for my latest project.
Joeaksa 06-25-2007 07:12 AM
Just retrieve them from where you backed up your data...
You DID backup your data didn't you???? Ahmmm, if not then do it now and learn from this.
Wouldnt Norton find these old files if the hard drive space had not over-written the area?
Super_Dave_D 06-25-2007 07:41 AM
Running a Windows system restore to the previous point will not do it. Since the names were the same - I think you may have lost them.
Stop calling pictures the same name - as an example: hot1, hot2 hot3 and so forth.
TerryH 06-25-2007 07:47 AM
This is easy to do if you don't name your files. Digital cameras can use the same numerical names if you reformat the memory chip or change chips.
Super_Dave_D 06-25-2007 07:50 AM
Originally posted by TerryH
This is easy to do if you don't name your files. Digital cameras can use the same numercal names if you reformat the memory chip or change chips.
Correct - didn’t seem to be the case here. There is also a Free MS download that will enable you to rename 100's or 1000's of file and it will sequentially change them to actually mean something.
http://support.microsoft.com/kb/320167
Once you dowload this - its a 'right click' option.
