-   -   Does this mean I broke my knee cap? (http://forums.pelicanparts.com/off-topic-discussions/357978-does-mean-i-broke-my-knee-cap.html)
Jeff 07-19-2007 10:50 AM
I received the MRI report on my knee today and am unsure what some of it means.
I understand I have torn my meniscus but, the rest I don't understand. Here is what the report says...
Severe fissuring of the medial patellar facet is present. Mild lateral tilt of the patella is seen.
and this...
A moderate effusion is present. Pericapsular edema is demonstrated posteromedially, likely reactive associated with recurrent meniscal tear.
If anyone can explain this to me I sure would appreciate it.
Thanks.
competentone 07-19-2007 11:02 AM
Wasn't this MRI accompanied by a visit with a doctor? What does he/she say, in plain English, about the results?
Or have you just given us an example of some sort of "mill-medicine" experience (the sort we will get a lot of if we get socialized medicine)?
sammyg2 07-19-2007 11:04 AM
I'm no doctor, but that sounds similar to what I was told a few years ago. I had a torn meniscus and the bones were rubbing on the back of my knee cap causing an abraision and bruising.
I had othoscopic surgery and walked out of the hospital the same day.
It was sore for a while but I was back to work climbing stairs 10 days later. After about 6 months I couldn't remember which knee was operated on.
If a doctor doesn't show up and answer the question I'll go stay at a holiday inn express and see what happens ;)
Dueller 07-19-2007 11:18 AM
Severe fissuring of the medial patellar facet is present. = On back side of the patella it rides on a flat spot that has become grooved over time where its rubbed over the bone.
Mild lateral tilt of the patella is seen= patella has tilted to outside of groove.
and this...
A moderate effusion is present. = damage still going on and tissue fluid is building due to inflamation
Pericapsular edema is demonstrated posteromedially, likely reactive associated with recurrent meniscal tear= same thing...inflamation from the tear w fluid buildup.
Does not mean you've broken your kneecap.
Jeff 07-19-2007 11:21 AM
competentone, Went to doctor monday, MRI tuesday, received the report and scheduled an appt. with an orthopedic surgeon beginning of august.
Sammyg2, Thanks. I had a meniscus repaired in the same knee 3 yrs ago, unfortunatly I had to be on crutches for 3 weeks due to a repair instead of just cutting the damaged part out.
Dueller 07-19-2007 11:27 AM
ooops...double post
Dueller 07-19-2007 11:30 AM
The meniscal tear was a traumatic injury, I suppose. The fissuring on the patella likely a chronic condition?
Dan in Pasadena 07-19-2007 11:34 AM
Condolences. I think the translation into regular English is, "Man, your knee is Fuched up!"
Dueller 07-19-2007 11:37 AM
Actually, I think a more accurate translation is "You're an old fart who wrenched the ***** out of a worn out knee climbing over the cage side bars." :D
Jeff 07-19-2007 12:42 PM
:D :D :D
I'd say you guys hit the nail on the head.
