Major SCO Unix issue, please help.
Hi!
My background is mainly in the various Linux distros, but I have picked up a little knowledge over time in SCO unix. Enough that I help out a Hydraulic co., that makes a lot of parts for the military. They are using an ancient 486 server with SCSI drives and SCO. Early morning Friday, a keyboard extension cable shorted - good thing it did not catch anything on fire - and killed the MB and possibly the HDD as well. The main SCSI drive is starting to click and sometimes is not recognized. I have used a device once before, but do not have access to it any more and was able to clone the drive once before when it failed. Now I am trying to use Norton Ghost, but it is not seeing any SCSI drive, even though I am loading SCSI drivers. That's one problem. The other problem, is that it seems that SCO does not like having disk geometry changed. How can I duplicate the existing HDD to a new (old) SCSI drive, that does not have the same geometry? Any ideas would be most helpful. I need to call the company in the A.M. and give them an update. I would really like to get this done this evening though. They will be switching to a Windows based software system in the next couple of months, so I just need the SCO box to run a little longer. Dave |
I have not tried Acronis yet, but will. You are right on the SCSI cards. All the Adaptec cards I have tried are 2900 series. I do have one SIIG AP-10 Fast SCSI2, but that did not get recognized either. I wish I had the old cloning machine. It was slow, but would duplicate almost anything.
Dave |
Dave,
Clicking SCSI drive coupled with no recognition sounds like a termination issue. Check the drive, card and cable. Any of the three are capable of providing termination, if more than one of them is you'll have issues. A terminating cable is easy to spot. My experience with cards is they do not provide termination by default, at least not on the external bus. Start with the drive. If I had to guess I'd say the jumpers are not set to terminate. Any other SCSI devices in the chain that could cause an ID conflict? The 2900 series is pretty vanilla, I'd stick with it. WHere is the drive? External case or are you putting internal on the PC? |
The drive seemed to click a few times while I was at the business and at first, was not recognized, then it was. The owner also said that the machine seemed to faster on some days. I have everything hooked up to a temporary (faster) machine, but now I can't get the MB to boot my cd first. This is minor though.
As far as termination, The server has been running without major problems in its current config for years. I have only had to save the SCSI drive once, but strangely, I see no terminator on the cable at all. The devices normally connected are 1) SCSI drive (OS), 2) removable backup SCSI drive, 3) SCSI CDROM I have not looked, but can this auto terminate? Acronis did recognize two other SCSI drives I was playing with, but neither has an OS to copy over and one of the drives is the spare backup HDD they keep just in case the main OS drive and it is bad now. Yikes, they should have migrated many months ago. Wayne, I am all too familiar with killing HDD's myself, but they do have a backup of the important data, they would lose only one days work. After all this is done and they are on the new system, I may see if I can keep their old server and frame it. It's a real piece of history :D, too bad it smells like hydraulic fluid. <- And now my house is starting to smell too. Thanks for the ideas so far. Looks like it is time to walk to the store and get some beer. This may be a long night. I also have another drive I need to recover as well. Dave |
I have been doing recovery on hard drives for a long time and know when it's time to send it off. This is also why I am trying to get everything setup with other drives first, so I don't put additional strain on the potentially bad drive.
I learned a personal lesson a number of years ago. I wanted to copy a bunch of vacation pics from my laptop to one of my Linux servers for a backup, but I accidentally moved them and one day, the server crashed. The platters were actually scratched from the heads. Total loss. The pros have a lot of tricks before they go to the clean room. One is to switch circuit boards from a good identical drive ;) Dave |
Are you working with the original server or is everything hooked up to a different box?
SCSI is great but there is a bit of vodoo to it. If everything has been moved you need to a) check for conflicts b) check for termination. Termination is easy, kind of. Basic rule is the last device in the chain gets terminated. Device ID's are set in order of the chain, 1st device having the lowest number, usually. It is possible to have some devices in a chain show up and not others even though the device works. Terminated cables are easy to spot, they will have a big block on the end. Won't look like a normal ribbon cable. Checking termination on drives is easy, look at or around the pinouts, the area on an IDE where you would set master/slave. The drive should have a schematic telling you what pins are what, sometimes it's printed right on the board. Termination is usually labled "term" SCSI Id's range from 0-7. The ID is acheived by jumping 3 pinouts. No jumpers = 0, jumper first set only = 1, jumper second set only=2, jumper third set only= 4. Jumping combinations gets you 3,5,6,7. jumper 1st+2nd =3, 1st+3rd=5, 2nd+3rd=6, all 3=7. CD drives like to be either 1st or last, not in between. Boot drives should be set to 0. Now if everything is still in the original server and the boot drive does not show I'd say it's fuched. |
The good, the bad and the ugly....
The good... Acronis sees two drives and all should be going well...
The bad... The spare SCSI drive the company has, may be bad as well and the only other SCSI drive I have is too small, well, I have one other drive, but no adapters for it... The ugly... From what I can tell, there is no practical way to image the drive to PATA or SATA, without causing SCO to freak on boot. If there is a way to do this, I can give them a temp machine and ditch SCSI. I found something on Google that seemed to say that there is some commands you can issue on the existing drive that'll allow this to be possible, but I may be wrong. Any one know for sure? Off to investigate one last SCSI drive I have. Dave I just got a call from someone and from what they said, it sounds as if the HDD failed, that makes three in a row. |
Dave |
Dave, you should be able to do this, however the solution is painful. If you have a ESX server you can P2V (VMware Converter) the Acronis image to a vmdk file. After that it can be restored in the virtual environment and moved to whichever hard drive platform you want to use. NOt the best solution I know, but we use it for DR from time to time. |
I used to deal with a Mom and Pop shop....i486, 800Mb scsi drive...I mentioned raid, tape backup solution and keeping the Long Hair'd cat out of the office.
well they lost all their data...root cause, power supply smoked due to fan failure and hard disk would not spin again. Cause: Long Hair'd cat hair clogged fan, PS and MB! lesson learned, if they wont dump a measly Grand in computer HW...walk away. Good luck with recovery...I know it can be a nightmare. |
Here's where it stands. The current HDD is 9 gigs. The spare that I took is only 3 gigs and is bad. I have two SCSI drives that were supposed to be taken apart for their staters, but never got a round to it. One is 2 gigs and the other requires a cable and card that I don't have. The current drive is not making funny clicking noises anymore. I wonder if termination has been a problem all along, but they have been getting lucky.
I no longer have the option to get another SCSI drive tonight, and really don't want to have them spend money on an over sized SCSI drive that'll be taken out of service in about two months anyway. Scott, have any leads on the hard way. I don't have access to a ESX server. |
So are these external drives? Not internal?
Some drives have a term toggle on them. Is your terminator active or passive? All academic as I think the drive is toast. If it was clicking when the server was functioning then, well, you know. |
I like fighting with Unix. Not many people left that know anything or want anything to do with it and it pays well :) Anyway, I'm off to the Quick-E-Mart. Dave |
I'm a pack rat with "that stuff" and keep it forever but am in the middle of moving. I just tossed a whole bunch of SCSI cards and known good 9gb Barracuda SCSI drives. Now I wish I had not as it seems you could have made good use of it. Sorry. |
I'd just rather be safe and clone the drive. Looks like I hold off and try to find an old similar drive around town or I figure out how to clone it to PATA/SATA... Dave |
I know this will sound funny, but i am not joking here..
Buddy of mine had a system at office, that ran on a 486 (companies, not his).... the payroll software wouldnt run on anything but Windows 3.1. Had no desire to move to modern system. HW was on last leg. He took P3 running W2k, with Raided boot disk, Ran an I486 emulator program and moved the Win3.1 and Payroll on to it. modern HW running the OLD os...something like 500X faster.....but safe. time for bed. |
Dave, I've got a closet full of Ultra-2, Ultra, and Reg SCSI drives and enclosures in my closet, with adapters, terminators, cables, you name it. Come get 'em. I think i've got 6 36GB drives ready to go.
Oh, wait. |
Thanks Jeremy! I just can't tell if you are being serious... I could have someone pick them up next weekend...
The one drive that'll work is an Ultra Wide SCSI and I don't think I have a controller or cable or the adapter it needs for the cable. I think it is time to try and get the old server running and use my terminator and see if it is happier. Dave |
Old server is up and the sweet smells of hydraulic fluid a wafting through my living room. The cd-rom drive is SCSI and is no longer needed, so I disconnected it. It did look like the cd-rom drive has built in termination with a jumper setting - looks like it was set to term. I also put the terminator after the removable drive bay.
Now I accidentally logged into X-win without a mouse. How do I kill the session with a keyboard? Thanks! EDIT: I was able to get to a command prompt! I am wondering if the drive is actually alright. No weird noises, nothing in the log files. |
I think the server is OK. It may be one of the backup drives that is failing, not good, but I can deal with that. It's been upgraded from a 486 to a Celeron 333 MHz and now has 128 megs RAM, up from 64. I will still look for a matching SCSI HDD and image this drive and use the new drive until the system change over.
The HDD that was dropped off this evening to me was not so fortunate. The PCB fried on the drive. This person has two options. I get the same drive, switch boards, dump data, switch boards back and they get lucky and will get another backup solution as well. If that does not work, they get to send it to a recovery service. We'll see what happens with tomorrow's case. Sounds like data may be recoverable.... Dave |
try Powerquest Drive image
it doesn't do file copies , but does a sector to sector copy in disk copy mode, it will copy disk 1 to disk 2, even if it doesn't understand the filesystem one bit, at least the older versions did, haven't tried the recent ones, still have the old one laying around here but i would think they retained this functionality |
It'll be sad when we retire this thing. I don't think I'll really get to work on another SCO machine. It would be nice to be able to learn how to install from scratch. Just have to make it two more months..... It'll actually be kinda of nice. This SCO system really does not have issues. I may get a call once every 6 months. When the migrate to a Windows network..... :D Dave |
the old drive image didn't care about what type of drive you had
could copy the scsci data to any other drive, and it would copy anything over as it was if the disk was bigger, it would still copy over as it was on the original disk and leave the rest blank so in your case, you snap up any old scsi disk that fit's your adapter be that 9, 18, 36 or whatever in size, boot, then drive image will copy over the stuff change the scsci id , presto you'll waste a lot of that disk by not using it, but it should work you could even copy it to an ata/pata (and probably sata disk) but that might cause recognition issues in SCO itself, driver not there drive image works from dos, antihing recognized in the bios, is a valid source/target |
Dave |
Next problem. I am onsite and it now seems that the removable backup drives are no longer recognized. How do I format a hard drive under SCO? I am looking online, but if anyone has the fast answer, let me know.
Thanks!! Dave |
I get the error:
mount: cannot stat '/dev/bkup' Arg!!! fdisk -p -f /dev/rbkp gave me some numbers then UNIX Active It looks like the removable drive is there and has an filesystem, but it won't mount. Dave |
All fixed! I figured out how to add the removable HDD's again and everything is working. Thanks for the help and ideas.
Dave |
| All times are GMT -8. The time now is 01:49 PM. |
