-   -   Submarine Project - Backyard and Garage Built (http://forums.pelicanparts.com/off-topic-discussions/366473-submarine-project-backyard-garage-built.html)
kach22i 09-11-2007 09:00 AM
Submarine Project by Doug Jackson, Backyard and Garage Built.
http://www.submarineboat.com/
http://www.submarineboat.com/sub/images/ballast3.JPG
http://www.submarineboat.com/sub/images/ballast2.JPG
http://www.submarineboat.com/sub/images/ballast1.JPG
http://www.submarineboat.com/sub/images/sub_aug07.JPG
Three soft ballast tanks will be used to trim the boat while submerged. One at the rear and two more at the front, just behind the cabin wall. Ballast tanks are simply containers that can store air or water in order to increase or decrease lift. Soft ballast simply means that bottom of the container is open to the water, so that the air inside the container is being compressed.
Pretty cool hey?
URY914 09-11-2007 10:39 AM
No thanks.
Mo_Gearhead 09-11-2007 10:39 AM
That would be cool to have.
Unfortunately, when put in use at any lake near me, the likelihood of trying to surface and having a 200+ H.P. BASS BOAT with S.S. prop. cut it in half would be a high probability.:) Periscope UP!
sjf911 09-11-2007 11:07 AM
Just be mindful of Murphy's Law.
onewhippedpuppy 09-11-2007 11:08 AM
After your hovercraft experiences, maybe not such a good idea?;)
stomachmonkey 09-11-2007 11:34 AM
And don't try running it in the East River in Manhatten.
cashflyer 09-11-2007 11:41 AM
I was thinking you had found one of these:
http://forums.pelicanparts.com/uploa...1189536042.jpg
Mo_Gearhead 09-11-2007 11:48 AM
From the above specs: constructed of 200 lb test Fiberboard!
We have a problem Captain!
Porsche-O-Phile 09-11-2007 11:53 AM
Wasn't there a guy on one of the "Monster Garage" episodes that had built one and actually sailed it from Atlantic to Pacific oceans through the Panama canal and everything?
kach22i 09-11-2007 12:08 PM
I got it to work though, making about 10 new improvments as I write this.
Another sub, but you get wet.
http://www.caribsub.com/
Doug's submarine is made out of aluminum...........just needs a hovercraft skirt and air screw propeller and we could have a FLYING SUB.:D
rammstein 09-11-2007 12:23 PM
Is that toy sub real? I want it I want it I want it!
I wonder if I would end up on a homeland security list with this?
MichiganMat 09-11-2007 03:07 PM
not the only way, but certainly a good way to find Davey Jones Locker
BertBeagle 09-11-2007 04:16 PM
I believe there is a good reason why subs are basically round in shape; instead of flat panel construction like this one.
Now paint it in camo, add a retractable top and it might make a decent duck blind.
futuresoptions 09-11-2007 05:52 PM
You must be an old sailor that is wishing for a burial at sea....
Can I have your car when you don't come back.....:eek:
Ahh, it won't be that bad, just remember when you get the emergency
hatch open to exhale on your way back up.......:D
Tobra 09-11-2007 06:54 PM
The shape has to do with resistance to crush at pressure. That box would concern me if we were talking about actually going deeper than 20-30 feet. Remember, on emergency escape, don't go up faster than your bubbles or your lungs might explode.
Capt. Crunch 09-12-2007 12:05 AM
Did you see the Columbian sub busted off the pacific coast?
