-   -   I let the smoke out!! really!! (http://forums.pelicanparts.com/off-topic-discussions/371924-i-let-smoke-out-really.html)
TimT 10-13-2007 05:02 PM
I powered up my desktop today, and all that happened was an acrid cloud of smoke was discharged from the power supply...
Im in the middle of doing some sheetrock and insulation work on mi casa so this release of magic smoke couldnt happen at a worse time..Anyway off to to obtain a new power supply..
The pc boots till it tells me disk boot failure or something.....
anyway Im going to build a pc tomorrow and see if I can salvage anything off the old hard drive....
BTW this message brought you via Panasonic Toughbook
id10t 10-13-2007 05:10 PM
You may have lost BIOS data... make sure your hard drives are still detected.
TimT 10-13-2007 05:14 PM
no boot.....it just hangs and givr a message after looking for the a:/ or cd boots.... when I look at the hard drive in DOS I can see all the files.....
How can I repair bios, or how can I direct the pc to the boot files.????
BTW
there is a boot manager on this system as I partioned the disc and have a linux partition as well a a window partition
ty for any advice
Joeaksa 10-13-2007 05:19 PM
Was the computer made by Lucas? :)
TimT 10-13-2007 05:29 PM
Nope built by a co-workers son....5 years ago it was the shizzle... aparrently its time to move on. Had been dead nuts reliable until yesterday.... just after I hit the on switch... smoke really came out of the power supply...
Installed a new power supply and no joy.....
SlowToady 10-13-2007 05:38 PM
Check to see if the ATX connector on the motherboard is burnt.
968rz 10-13-2007 06:41 PM
Sounds like it wiped out the boot sector for windows, What I would do is put that drive as a secondary (d ) in another PC, copy the stuff you want to the other hard drive (c ) and then reinstall it and install windows again. When running again just copy all the saved data back and you'll have a nice fresh computer.
id10t 10-13-2007 07:24 PM
Oh, in that case just boot with a live Linux cd like Ubuntu and chroot to your native install and re-run your bootloader...
Mule 10-13-2007 09:07 PM
here's an old trick. Double zip lock bag the HD & put it on the freezer overnite. Plug it in as a slave. It might run long engough to drag the data off.
