-   -   fender removal (http://forums.pelicanparts.com/off-topic-discussions/373260-fender-removal.html)
byfdinky 10-21-2007 08:32 AM
fender removal
When removing the front fender from my 1979 911 sc , I am stumped on how to get the headlight wire and connector through the small hole in the headlight bucket. Any Ideas?
azasadny 10-21-2007 09:50 AM
Bill,
Somehow, this got posted in "off-topic" and you'll get better results if you post it in the 911 technical forum. I did a search and found this thread, it may help a little...
http://forums.pelicanparts.com/showthread.php?t=267349&highlight=front+fender+rem oval
Hetmann 10-22-2007 11:40 AM
You can pull the wires out of the connector with the aid of a small flat blade screwdriver. Yoy can later reinstall the connector after you get everything fed back thru the hole on you new fender. Be gentle, don't break anything.
byfdinky 10-23-2007 03:11 AM
Thanks for the replies!
A small screwdriver inserted into the connector solved the issue!
Many Thanks!
Bill
1979 SC Targa
