Shaun @ Tru6's Avatar
Acid-etching metal foils
anyone here have experience "cutting out" complex shapes in metal foils using an acid-etching technique?
Our waterjet cutter, who did an excellent job with 1/4 inch Aluminum sheet, says he can't cut multiple layers of foil.
Any ideas on how I can make these in production quantities using various foils?
Tru6 Restoration & Design
Old 11-05-2007, 05:08 AM
Greasy Member
many944s's Avatar
I would try using a standard UV sensitive photo-resist.
Basically, you would coat your foil with a photo-resist film, and allow it to dry.
Next, place the template over the top of the foil, and expose it to a UV light source. A solvent is then used to wash away the resist that has been exposed to the light. Once the solvent is removed, a light acid mixture can be used to disolve the remaining foil. Lastly, you use another solvent to clean your foil piece.
All in all it is similar to a circuit board construction.
If you need more details, I think I have a catalog somewhere around here with all the materials you would need.
Hope it helps!
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 11-05-2007, 05:53 AM
hi Nick,
that is exactly what I want to do, thank you.
I'll google around and see what I can find for experimentation.
BTW, do you need a set of Lotus hubcaps? I've got a set I found recently in storage from a 66 Elan.
Old 11-05-2007, 06:16 AM
