Thanks, I'm learning this as you know. I had a similar discovery in our little postal scale from Pitney Bowes, I found we were leasing a $15 scale for $20 a month for 10+ years. :rolleyes: I have a lawyer go over our leases now. |
Charles, I agree the high volume stuff is impossible. This is a specialty item, in lowish qty's with higher margins. Turnaround time requirements and QC issues keep China at bay. |
Charles forgot to tell you to lie about the competitors price and cycle time to get them undercutting each other. Standard automotive purchasing practise nowadays.
My guess is the 'real' price is NOWHERE near the list price. Esp. if they sell you a demo model. And, (warning, generalization ahead) postage meter/copier companies are the biggest scum I have ever dealt with. |
Thanks, The worst thing about Pitney Bowes was that the scale wasn't even listed as a separate charge, I had to ask. Unreal. |
its a dog eat dog eat puppies machining world. have seen machine shops win huge accts(parts runs) for one (1) penny!!!! one ******* penny per part! after years of loyal perfect quality work.
i myself lost accounts for (1) one ******* penny per insert! our motto was giv'em the holders and they will buy the bullets(inserts). proprietary holders can only use that mfgs. insert. CNMG is cheapest geometry insert to use. cost from sandvik about .03 cents their cost to mfg. in a common steel cutting grade. get into coated inserts and price goes up. want to machine aluminum @ 10000RPMs(sounds like machine gun going off) on a mill...........use diamond coated inserts. last cost to customer i remember was a $110 an insert. pit everyjuan against everyjuan and when dust clears , you will have a quality part and good cycle times. machining center numero uno concern. numero dos.........tooling. numero tres.........coolant. and dont ferget to hire a damn good open minded programmer! hope that helps. |
I meant that our machine shop's "specialty" is building parts for special machines that we design then build.....although we on occasion will "quote" on big "machining only" jobs when our machine building business is slow, we rarely can compete against shops who only do machining. I was assuming the guys at your shop are good at making parts from tubing...I just worried about how you can suddenly expect to make a profit in strictly machining when you are new to the game. More power to you if you can, it just seems like a bit of risky endeavor from my POV. |
I've lived through a few machine installs, and done just about everything from engineering (new product), CAM/programming (lots of custom stuff including MasterCam post processors, CNC macros, etc), full manufacture engineering and optimization of heads, cylinder heads, crank cases, connecting rods, etc, lots of job setups, and even running machines (earlier in life). Most of my CNC experience is with larger horizontal Toyoda machining centers. Keep in mind no machine new or used is going to hit the floor running. There are all sorts of things which will need doing before you are ready for production, 1.) Like obvious stuff, setup bus to get electricity, route compressed air, and make sure you have a good electrical ground. 2.) If bad floor and large machine, cut, dig down and re-pour concrete for proper foundation. Can happen, crappy floors make for unhappy machines... 3.) Install could take a while. Some machines come in parts. Mover drops off parts, factory guy(s) finish it on site. Then of course when finished they have to lazer in the machine, calibrate the probe, etc, etc. 4.) If you have a set in-house common pallet / fixture plate, you might have to machine a new adapter plate for the new machine's pallet or table. 5.) Then of course there is first run part setup which is always going to take a while. Setup off all the tools, inserts, offsets, fixtures, etc, etc for the job. As for new vs used, I'd suggest used if you are careful where you get the machine from. Assuming the used machine isn't too beat up (and it has good positional repeatability), the difference between the new and the used machine boils down to positional accuracy which you can adjust for when the machine gets lazered in. You are going to have to lazer (re-calibrate) the machine and the probe (more often) periodically anyway new or used. Install for either new or used is going to be about the same. Ultimately if you have a really smart programmer, you can get around all sorts of stuff (problems) by having lots of offsets and probing things (part or fixture). Even a perfect machine is only accurate and repeatable to a certain point. Temperature, fixture wear, job swaping, etc, etc, all add in so many other variables that you are going to have to have a bunch of offsets in a program to comp for the unknowns, so machine wear quirks (on a used machine) just is another thing comped by offset adjustments (the lazer calibration cannot fix everything). I'd suggest no matter what machine you get, make sure you have ethernet (standard computer networking access) to send programs to/from machine. If you are lucky and have a dedicated part for a given machine which can run 24/7 then you are in an ideal situation for amortizing the cost of the machine. However if you are running just one shift or have to job swap, ultimately labor inefficiencies (setup, change over times, down time, etc) are going to be the primary factor in profitability (through the life of the machine). I say this only because simple expensive machine options (depends on manufacture, like ethernet, in-machine tool offset probe, etc) can have a tremendous benefit in reducing change-over time for a job shop and are IMHO very worth it. Anyway good luck with your project! |
I'll admit it's an 8 or 9 on the difficulty scale and we're used to 4's and 5's but we need to go where the money is and this company is willing to let us give it a run. Regarding how we can compete, that's actually pretty simple. Our overhead is nothing compared to the shops that normally get this kind of work, seriously not even in the same zip code. If my father didn't have such an "in" we would NEVER get a shot at the work, not in a million years. The carrying costs of the machine (even at 500-700k) are very small in relation to the revenues. |
Thanks, We've gone through machine installs before and you speak the truth. One thing I should probably clarify is that we would not be doing the programming or fixturing, this will be handled by an affiliate of the manufacturer. When I say "hit the ground running" I mean as much as is possible given our approach. |
| All times are GMT -8. The time now is 01:40 AM. |
