-   -   Question for Engineers (http://forums.pelicanparts.com/off-topic-discussions/380265-question-engineers.html)
Shaun @ Tru6 12-01-2007 04:53 PM
I want to devise a machine where a metal door is opened, closed and held in a constant variable open position with electromagnets. the electro part would be tied to simple mechanical input, say the opening and closing of another door.
how difficult is something like this to mock-up?
legion 12-01-2007 04:56 PM
Just make sure your are not standing anywhere near it if you (or your children) have magnets in your pants...
1fastredsc 12-01-2007 05:12 PM
Your probably better off trying to come up with something like using a stepper motor to control the door, but i'm sure there's a way to do it.
9dreizig 12-01-2007 05:32 PM
Shaun,, what kind of door ? I sell linear servo motors ( all magnet driven) Check out the linear servos at www.nipponpulse.com let me know what you think..
T
M.D. Holloway 12-01-2007 05:50 PM
I guess you could have the tracks lined with electromagnets and send a signal to the various magents would trigger a response. You could shift the polarity to make it step to the next position - think of a nuke accelerator.
Seems like a very expensive aprouch to a problem that can be solved with a chain, sprocket, worm & drive gear, motor and a servo.
Shaun @ Tru6 12-01-2007 06:28 PM
thanks guys. I was a little vague on the action of the door, sorry.
the door won't swing open, but will slide open. so I need something that will pull the door open without a mechanical device like a gear or hinge, and it needs to be able to be carefully controlled on how far it opens, stays open, closes, etc.
Todd, sending you a mail.
many944s 12-01-2007 06:58 PM
How big of a "door" are we talking about? If this is a small application, I would modify a vacuum system gate valve. Of course, if you are talking about a "walk-through" door, this type of device is useless.
Just a thought,
-Nick
Shaun @ Tru6 12-01-2007 07:04 PM
thanks Nick, the door is very small, something a mouse would go through. The door sliding open and closed has to be immediate and precise.
HardDrive 12-02-2007 02:20 AM
Is there porn involved? PLEASE POST VIDEO.
red-beard 12-02-2007 06:24 AM
We use fully electric control valves like this. Look for "Electric Actuators"
Shaun @ Tru6 12-02-2007 06:28 AM
Originally Posted by Wayne at Pelican Parts (Post 3620231)
Sounds just like the idle control valve!
-Wayne
Nope, just a bad attempt at creating a closed system for slide valve throttle bodies that won't be prone to sticking with particulate contamination. offline folks have set me straight.
I'm going to focus on standard mechanical action with frictionless coatings.
M.D. Holloway 12-02-2007 12:23 PM
How tight does the seal have to be? Airtight? Will it have to keep back a fluid? Is the speed of actuion a concern?
