Cars & Coffee Killer
legion's Avatar
Full-Circle Disc Brakes?
I was watching "How It's Made" the other night, and they featured a segment on full-circle disc brakes. Part of the segment even has a 911 running in the Motorola Cup with them. I'd never heard of these before.
While I can understand why they are not used on most production cars (I'd imagine they are expensive and hard to work on), I don't get why they wouldn't be used in racing and on expensive, high performance vehicles.
More info here:
http://www.brakingtechnologies.com/PDF/SAEPaper.pdf
5 liters of VVT fury now
-Chris
Old 12-19-2007, 07:41 AM
Evolved
Mo_Gearhead's Avatar
I'm no mechanical engineer, but it seems like 'overkill' for a car, even a race car.
Heat dissipation would be one consideration.
Ever see night photos of brake discs at 24 hr races ...glowing red hot?
Once you got heat built up in those baby's (they look like twin clutch-packs) ...that might be a problem.
Now for stopping a landing aircraft, or other applications...?
Don't fear the reaper.
Old 12-19-2007, 07:51 AM
Super Moderator
cstreit's Avatar
My 3 year old and I watch this show every day.
At first I thought that this was a really good idea, but then I wondered if there really was an advantage... If the current brake caliper technology can lock up the tires even on the stickiest of rubber in race conditions, what would MORE pad surface do? I suppose it would allow for more heat dissapation in the caliper itself (similar to increasing rotor mass, you increase caliper mass), but is this really an issue? Would the problem of unsprung weight increase offset the advantage?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-19-2007, 07:57 AM
legion's Avatar
Because of the increased surface area (and increased friction), couldn't you stop a car by applying less brake pressure than in a conventional system? Could you possibly eliminate the brake booster?
-Chris
Old 12-19-2007, 08:03 AM
Moses's Avatar
What serves as the primary heat sink in brakes, the rotor or the caliper? If it's the rotor, thicker, vented rotors make sense. If it's the caliper, full circle calipers make sense.
Old 12-19-2007, 08:11 AM
IROC's Avatar
Increased surface area does not equal increased friction. In the classical look at the forces involved in friction, there is no term for "area". Here's the equation:
F = mu*N
where F equals the friction force, N is the normal force applied (how hard you're pushing the brake pedal for instance) and mu is the coefficient of friction. Area doesn't matter. I would imagine that a disc brake set-up approximates the classical application pretty well, so pad area doesn't make a difference in friction force. What pad area does give you is longer lasting pads and supposedly better feel. I'm sure Bill V can add more to that.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 12-19-2007, 08:20 AM
New kid in town
71T Targa's Avatar
Then why does a wide tire grip better than a skinny one?
I wish I still had 9111113443...
Old 12-19-2007, 08:34 AM
IROC's Avatar
The frictional interaction between a tire and the road is pretty far removed from the classical application. Alot of the friction generated between a tire and the road is due to the relatively soft rubber of the tire interacting (and getting ripped off) by irregularities in the road. F=mu*N doesn't work very well. In fact, if you look at the plot of frictional forces generated by a tire as a function of normal load, the curve isn't even linear.
Mike
1976 Euro 911
Old 12-19-2007, 08:47 AM
Banned
unsprung weight ????
Old 12-19-2007, 09:12 AM
Braking, the company producing the full circle brakes has been around for a while. I remember seeing their booth 8 or 10 years ago at the SAE Congress in Detroit. Their product has not caught on for the reasons listed, it is heavier, more expensive, more difficult to service, has cooling issues and does not out perform lighter, cheaper, simpler solutions.
Old 12-19-2007, 05:24 PM
Blanco's Avatar
Heck.. this might be a good application for semi-trucks and trailers. 5 Axles to provide stopping for 80,000lbs, but at what cost?
I've seen some semi's with disc brakes now, appears they are making a comeback.
1982 Porsche 911SC Coupe - Factory Short Shift |7:31 R&P in AL case | Toyo RA1 Tires | Corbeau TRS seats | M&K 2 in 2 out muffler
Old 12-19-2007, 07:14 PM
Slackerous Maximus
HardDrive's Avatar
I watch How Its Made with 4 year old all the time too!
2014 Cayman S, PDK
Old 12-19-2007, 10:24 PM
