-   -   Photography Question (http://forums.pelicanparts.com/off-topic-discussions/383499-photography-question.html)
masraum 12-25-2007 08:26 AM
Originally Posted by Joeaksa (Post 3664554)
I shoot RAW and it works beautiful. Photos are large (30-40 megs each) but my God the quality.
Joe
I shoot raw as well. 30-40MB? What kind of camera do you have? I thought that raw should give you an image that's approx the same size as the megapixels of the camera. IE, my Canon is 8.0 or 8.1, and my images are usually between 7.0 and 8.9
masraum 12-25-2007 08:35 AM
Originally Posted by 911pcars (Post 3664453)
There's only so much one can do with an underexposed scene no matter if it's high res jpg or raw.
Here's one. Anyone care to try fixing it?
http://forums.pelicanparts.com/uploa...1198569668.jpg
It's easier to "fix" if the exposure and the lighting ratio are closer to ok.
Sherwood
This one is so under-exposed, it'll be hard to fix. Also, since it's jpg and not raw, that'll make it even harder to fix.
masraum 12-25-2007 02:33 PM
If I had the raw image to work with it would have come out a lot better. Not only is this a jpg, but it's also only 18k which means that a lot of the detail has already been lost to the compression algorithm. The better the image that you start with, the better the end result.
Here's about the best that I could do with it. I'm far from a pro. I just tinker, novice at best really.
http://forums.pelicanparts.com/uploa...1198622018.jpg
911pcars 12-25-2007 05:33 PM
Steve,
Thanks for the effort. I just wanted to show that software can only compensate so far. As in film, the elements of an image must be recorded in order to enhance it. Software solutions only go so far.
Minimum threshold light for proper exposure is the solution. Bracket if in doubt.
Sherwood
BTW, that's me (far left) sitting next to my son at my niece's wedding.
Wickd89 12-25-2007 07:54 PM
Fix:
Get a Nikon associated flash. Use a bounce or diffuser and you should be fine.
Get the best lens you can afford. Hopefully a fixed 2.8 or better.
Get a good filter (protection).
Use a lower ASA/ISO setting for 100 or 200.
Existing light is great, but for people shots, you really need people to pose and a tripod, etc...
campbellcj 12-25-2007 11:29 PM
FWIW, the last 2 nights I ended up using the D200 pop-up flash in CLS "commander" mode with an remote SB-600 bounced off the ceiling. It worked far better than the camera-mounted SB-600 I used last year. I have an SB-800 on the way so I can try some true multiple-flash stuff next.
Merry Christmas everybody...
