Guess this engine!
Here is the car, a 1929 Ford Model A:
http://forums.pelicanparts.com/uploa...1201615649.jpg Here is the engine, also by Ford: http://forums.pelicanparts.com/uploa...1201615678.jpg http://forums.pelicanparts.com/uploa...1201615696.jpg Hint: this car does 0-60mph in about 5 seconds :cool: |
Ardun OHC?
This is a DOHC four cylinder. |
Ford Escort BDA twin cam by Cosworth
Revs above 8K @250 HP (Check the front license!) |
OK, I thought Ardun also made 4 pot heads Quote:
Cortina GT?
Looks like masked Cosworth 16v head. Belt goes wide so there are twin pulleys underneath.
Are those drag radials on those wood spokes?
Here is video of the beast: http://www.mat.fi/video_aford.htm Here is a photo gallery: http://www.mat.fi/project1929fordmodel-a.htm Mäkelä Auto Tuning of Finland built this car for a (no-doubt wealthy) client. Check out the photos; the engineering and craftsmanship are amazing. |
Awesome sleeper.
Here is what the actual model A motor looked like, http://www.antiqueenginerebuilding.c...s/engine_a.jpg http://www.antiqueenginerebuilding.c...s/engine_b.jpg You might be surprised to know how many model A's there are on the road still, not bad for a late 1920's vehicle. The model A connecting rods had a babbitted bearing, were created from a 2 part forging, complete with an oil scoop on the cap for "splash fed" oiling. I worked on the design and manufacturing for a modern aftermarket replacement rod with a shell bearing. Comes in multiple variations for two types of pistons, and one without the scoop for pressure fed conversion motors. http://www.connectingrod.com/img/engineering.jpg |
The wheels were custom made aluminum painted to look like wood. It is in this months Hot Rod. Lots of cool features, check it out
I was reading this artical as one of the guys in the office sent it to me. The guy who did that car even put a mis-fire circuit in there that he could switch on and off. When in mis-fire mode it would cut every third spark so it sounded like an old timer. That car is super cool!
Here's the page... http://www.hotrod.com/featuredvehicles/hrdp_0803w_1929_model_a_touring_car/index.html |
http://forums.pelicanparts.com/uploa...1201633263.jpg Very cool |
Simply insane craftsmanship. Just unreal.
According to Hot Rod, the owner is an annonymous Finnish former WRC driver who found the car during a 1993 rally in Argentina. Who would that be? |
Anyone ever driven a stock Model A? There seem to be a few around for not much $$. Are they practical to drive on the weekends, or are they best left in some one else's garage?
Brakes were always an issue on Models A's. But you can make a nice weekend driver that would hold it's value.
Grandfather has 5 or 6 normal Model A's. Great for putting around the countryside at 30-40 MPH, somewhat scary when you go much faster. Not exactly a "driver's car".;)
A good friend of mine restores and shows Model A's. I went for a drive with him a couple of weeks ago in one of his cars. It's all stock except for a high compression head, overdrive, and banded brake drums. It cruises at 60 mph very comfortably, and the brakes work great with the bands that keep them from expanding when they get hot. I was amazed at how easily it cruised on the freeway - I thought they were slow rattle traps - I was completely wrong.
| All times are GMT -8. The time now is 04:46 PM. |
