restored laptop to original configuration..problems..
it's a dell inspiron 9300. first thing i did was organize data folders with family pics, documents, etc. that i didn't wanna lose and cut to a portable hard drive. then i forgot until it was too late, after doing a F11 command and making it restore itself to the original point when i bought it (remanufactured)..prompting me for country, language, time-zone, etc. in doing so, i lost all of my installed programs that i did myself, as well as forgetting to move about 500 songs i'd downloaded over two years...ouch! don't guess there's anything i can do about losing them as well as all my bookmarks..forgot to save that file as well (it was the middle of thenight and i should have left it well enough alone).
other problem is that my dvd+rw drive won't play. it lights up, makes sounds here and there, but never gets to spinning up. right-clicking the drive and checking the device, it says it's working properly. the laptop did suffer a little fall a few months back..could it have just loosened a cable inside? if so, is the drive easily removed or is time for the 'geek squad'? i've taken apart and re-worked a few desktops in my day, but never messed inside of a laptop. any advice? thanks! ryan |
holy cow...windows media player just did 'do you want to look for more music files' question during new configuration and found my 580 songs! :) well, that part's a huge relief!
spoke too soon.. :( only found some, maybe 50. i think most of it was in the 'shared folder' under doc's and settings that was cleared out when i forgot to move those files to the portable drive during the reset. crud..
is the dvd a dual cd/dvd device?
they have 2 lasers, one for cd, one for dvd. sometimes one laser fails and not the other, try various media |
thanks. yes, it will operate both. just checked..it will play a dvd, but won't recognize a blank or installation cd... :(
There usually is only one laser that adjusts its height and intensity. Having taken many apart for the laser and rotor, I have never found two.
Check the recycle bin, might be some files in there that you want to restore.
Don't remember the specific model number/manufacturer. |
Just because you have not seen one yet does not mean it is not true. |
You can take a laser out of an optical drive and in about half an hour, create a little laser pointer that will actually cause a match to combust or pop balloons |
it's a sony dvd+rw DW-Q58A......?
Every now and then, a low level driver in Windows corrupts and you have to go into the registry remove the entry and reboot. Windows will rebuild the registry key and your drive may work.
These are the two registry keys you need to find and remove.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}\LowerFilters HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}\UpperFilters |
found the registry keys, but not where it says \lower filters or upper filters?
nope, found a line that says lower filters, but not higher....should i go ahead and delete the lower filters line?
Here's a screen shot:
http://forums.pelicanparts.com/uploa...1203633382.jpg If the upperfilters line does not exist, don't delete it ;) Delete the lowerfilters, close regedit, reboot and see what happens. |
| All times are GMT -8. The time now is 09:22 PM. |
