Custom User Title
PC Memory Upgrade Headaches
OK- here is the basic data-
My motherboard has 4 memory slots. Currently, 2 are filled with 512mB sticks. From my boot menu, it indicates that it is PC2-3200 DDR2 memory @ 400MHz. I bought 2-1GB sticks of DDR2 PC2-5300 which claims to be backwards compatible with PC2-3200 @ 400MHz. It also says 'dual-channel' on the box. Long story short- it doesn't work. I tried a few configurations, but with the new ram inserted it simply doesn't boot. No boot. Even taking out the old ram altogether and leaving just the new RAM installed, no dice. Tried using the correct slots, tried the incorrect slots. Is the 'dual-channel' part screwing me? I don't know if I have dual channel or not. I would have thought I did based on the 4 slots, with each pair color-coded, but perhaps not. In other news, I installed a real video-card (e-GeForce 7600GT) and Warcraft looks AMAZING now. Unfortunately, in the process of installing it, my computer no longer finds the CD-Drive as a boot device, and warns me of this with every bootup. Nevermind the fact that the drive works fine, it just doesn't 'see' it on bootup anymore. ARRRRRGH!!!! |
The Unsettler
How old is the box?
What motherboard? If it's too old it may not support 1 GB sticks.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Senior Member
As noted above, you need to find out what type of MB you have, and see what it will handle.
Make sure you find out which slots are 1 & 2 and use them first. Then max it out with RAM.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
If you have four slots, they are paired up. Should have colors like Slot 1 - black/blue, Slot 2 - black/blue. That type of MB needs to run *matched* memory in each slot. At least i stick in each bank (i.e. the two black slots). If you want to fill the other two slots in each bank (the blue slots), you would (more than likely) need to fill them with two 512 sticks of RAM.
If you have tried all available configurations, it could be that the memory sucks. What brand is it? You should at least be able to take the two new 1 gig sticks and put one into each slot like above. Probably really confused you on this....
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Custom User Title
The slots are labeled appropriately, as to which ones are which. Filled 1 and 2. The sites I have checked claim my motherboard will read 1 gig cards... currently in there are 2 512 sticks.
Again- coud it be something to do with dual-channel stuff? |
What brand memory did you buy? What is the MB make and model?
Seriously, there is really crappy memory out there. I only try and buy Kingston, but Corsair and one more that is escaping me.
Also, the gig sticks. Are they ECC or non-ECC? If you happened to buy ECC memory, it won't work at all.
Custom User Title
The memory I bought is non-ECC, for sure (it says so, and the number of chip thingies isn't divisible by 3 or 5).
The brand is PNY. The size of each stick is 1 GB. Model is DDDR2 PC2-5300, dual channel. Here is my computer data: Dell Inc. Dimension 4700 Board: Dell Inc. 0M3918 Serial Number: ..CN7082153300SW. Bus Clock: 800 megahertz BIOS: Dell Inc. A06 01/10/2005 1024 Megabytes Installed Memory Slot 'CHANNEL A DIMM 0' has 512 MB Slot 'CHANNEL B DIMM 0' has 512 MB Slot 'CHANNEL A DIMM 1' is Empty Slot 'CHANNEL B DIMM 1' is Empty |
Monkey with a mouse
Would a RAM analyzer program be of any help?
Best, Kurt |
Custom User Title
Good call on the analyzer- I had used the analyzer on crucial.com to find out some stuff, and it told me:
Currently Installed: DDR PC2-3200 512MBx2 Then it goes on to say Each memory slot can hold DDR2 PC2-4200,DDR2 PC2-6400,DDR2 PC2-5300 with a maximum of 1GB per slot. What is particularly perplexing about this is that DDR2 will not fit in a DDR slot, and the crucial system scanner claims my current RAM is DDR, and it obviously isn't because: A) the DDR2 ram I bought physically fits just fine B) my BIOS says I have DDR2 Ram Last edited by rammstein; 03-09-2008 at 09:52 PM.. |
Monkey with a mouse
How about an analyzer that actually checks the integrity of the chips?
FWIW. Best, Kurt |
Custom User Title
How does that work? Never heard of it.... man, I thought I was gonna snap these in and be pimping one click later. Instead, now I have to cry. ;(
Can you burn an image from an ISO to a CD? Not an answer to your ?, but let me know.
Monkey with a mouse
Are you running XP? I can look for a RAM tool. Best, Kurt |
Here:
http://www.memtest.org/
Custom User Title
I assume I am answering the question correctly- yes. I at one point downloaded an ISO burner to make a copy of something.
Monkey with a mouse
Here's one that's free: http://hcidesign.com/memtest/download.html
edit - Dave beat me to it! ![]() Best, Kurt |
Custom User Title
I am running XP.
If my PC won't even boot when I install one of these mem sticks, how would memTest be able to function... I DO appreciate everyone's help. I just wish I was smart enough to figure this stuff out. |
Monkey with a mouse
Yes, that's a problem.
Hmmmmm . . . I dunno ? ? Dave is smarter with this - I'm less than a Windows expert. Good luck and sorry I couldn't help more. Best, Kurt |
I'd suggest taking the PNY back. I don't care for it. You have a PM. Does the computer beep if you only have the 1 gig sticks in?
