-   -   WOW I own a flex fuel car didnt know it (http://forums.pelicanparts.com/off-topic-discussions/404213-wow-i-own-flex-fuel-car-didnt-know.html)
kwm 04-16-2008 05:53 AM
I have a 01 Chevy S10 that I bought slightly used in 03. I was trouble shooting what I thought to be a slowly failing fuel pump and stumbled across, what is I guess a fact, it being a felx fuel E85 truck. Before people start to slam me here: A) I did read the manual front to back, B) there is no sticker or badge anyplace on the truck alerting me to this C) only one small paragraph in the manual does say that if your S10 is a L2200 4 cyl engine with a 5 as the eight digit in the VIN it is designed to run E85 or 87 oct gas.... Anyway, I found 1 of only 3 stations in the Charlotte area that sells E85 and I plan to go there today after work but with a lot of trepidation I can tell you that much. E85 is selling at this place for $2.79 where gas in my area is $3.33 or higher. I went to buy a fuel filter at the auto parts store and baulked at the almost $40 price and was like what the fuel filter should be like $10 bucks. He said it is $10 or $11 on the gas only S10 for the 2000 model year but yours is a 2001 flex fuel.... I was like no it is not! Then he showed me what a flex fuel filter looks like and what the standard gas one looks like and sure enough the truck has a flex fuel filter on it. Has this by chance happened to anyone else? Should I be worried about putting the E85 in it at all?
Scott R 04-16-2008 05:56 AM
My brother has an 01 Tahoe that accepts E85, at 2.70/gallon he's lost money vs. 87 octane. Its easily a 20% reduction in millage, sometimes more.
kwm 04-16-2008 05:58 AM
Scott do you think that would be ameliorated at all by the fact that I have a 4 cyl isn't the Tahoe a V8?
Scott R 04-16-2008 06:01 AM
Good point, had not considered that, you may as well try.
kwm 04-16-2008 06:04 AM
Scott I like your SC set up, "9:8:2 JE's SSI's 964 CAMS Heater Backdate M&K ". Did you own the car stock at all if so where on a scale of 1-10 would you put the engine perf. where it is now compared to stock? Thanks
MRM 04-16-2008 06:05 AM
Being in the grain belt up here, E85 is a pretty big deal. Most people don't know it but most Ford trucks and SUVs in recent years are E85 compatible and many other SUVs are too. I haven't heard the same anecdotal reports of that big of a loss in mileage, so I strongly suggest trying it and see if you like it.
deanp 04-16-2008 06:13 AM
See here for some additional info:
http://www.cars.com/go/advice/Story.jsp?section=fuel&subject=fuelAlt&story=e85
http://e85prices.com/
http://e85vehicles.com/2001-s10pickup.htm
deanp 04-16-2008 06:15 AM
Also here:
http://www.fueleconomy.gov/feg/calculatorCompareSideBySide.jsp?column=1&id=17307
Scott R 04-16-2008 06:24 AM
I owned the car stock, and it slipped to running on 5 cylinders before I rebuilt it. The performance over stock is pretty amazing, the torque curve on the dyno is almost straight up on the graph. At 3k rpm's if you step on it, the front end lifts (not off the pavement) due to the torque. In short, I love it. Currently its at my p-car wrench to get dialed in, the CO needs to be upped to add more fuel.
onewhippedpuppy 04-16-2008 06:37 AM
E85 will always give you 15-20% less MPG, ethanol has less internal energy than gasoline. Many new cars from Ford and GM are FlexFuel. In some cases, it's the only engine they offer.
Evans, Marv 04-16-2008 07:40 AM
I like to put bio in my truck. The place I buy it also has E85 as well as propane. The problem is it's only one of two (I think) places in the whole county that sells it.
the 04-16-2008 07:56 AM
Do flex fuel cars get less mileage (compared to a non-flex car), even when running on regular gasoline?
I recently had a Chevy Impala 6 cylinder rental car, flex fuel. I did almost 700 miles, all highway, running on regular gasoline. According to the trip computer, averaged 70 mph, and 22 mpg. Mileage seemed low to me.
masraum 04-16-2008 08:10 AM
I know that when they added the 10% crap to the regular gas here last year, my mileage went down by about 10%.
TheMentat 04-16-2008 08:25 AM
That is strange... that suggests that the additive has no "internal energy"...
fuelie600 04-16-2008 11:37 AM
My '02 suburban mileage drops from 16MPG on 87 to 12.3 on E85. (both highway)
It's rare that the price difference makes up the difference.
E85 does smell good though....
onewhippedpuppy 04-16-2008 01:42 PM
10% ethanol by volume, ethanol has less internal energy than the gas it replaces. Your car has to burn more for the same output, so less MPG.
BGCarrera32 04-16-2008 01:49 PM
Its such a big deal in fact, I can only think of 1 gas station in about a 15 mile radius from my house in the northern suburbs that carries E85.
And, you get about 70-75% of the BTU's per gallon vs. a gallon of gasoline.
TheMentat 04-16-2008 03:29 PM
Huh???
If you add 10% ethanol, and your car has to burn 10% more fuel, doesn't that suggest that the ethanol produces approximately ZERO energy?
Someone's calculations are off by alot...
Gogar 04-16-2008 04:51 PM
I"m just really impressed; I've never heard someone use "ameliorate" in a sentence.http://forums.pelicanparts.com/support/smileys/wat6.gif
MRM 04-16-2008 05:55 PM
Where are you? I'm in Vadnais Heights and have three within a few miles. More on the way downtown. Maybe you just need to look for them.
rick-l 04-16-2008 06:45 PM
Originally Posted by TheMentat (Post 3890411)
Huh???
Are you arguing how the sentence is worded? I would take 10% ethanol added to mean it was 10% ethanol 90% gas. For ten gallons you would have 1 gallon of ethanol and 9 gallons of gas.
If that is not the case how do you calculate this? With gas I get 25 MPG so 10 gallons of gas I can go 250 miles. With 10% ethanol it takes 11 gallons to go 250 miles (10% more fuel). The 25 mpg is now 22.7 or 10% less.
red-beard 04-16-2008 07:50 PM
BTU content of dry ethanol is aproximately 75% of that of Gasoline for the same volume. BUT, alcohol is also hygroscopic. So the BTU content can actually be quite a bit less, by the time it used. Regular Gasoline these days is supposed to be 90% gasoline, 10% Ethanol. It might actually be 85% gasoline, 10% ethanol, 5% water.
E85 can be far far worse. It is supposed to be 85% ethanol, 15% gasoline. It might be 30% water.
And the taxes are based on gallons, not BTU content. So, yep, you get double screwed.
Welcome to how our government screws things up.
TheMentat 04-16-2008 09:03 PM
What I'm trying to say, is that, you would only get a 10% decrease in mileage if the ethanol in your example had zero BTU content...
using a 75% equivalence to gasoline, and assuming that BTU content is directly related to fuel efficiency, a 10% blend would only decrease mileage by 10% x 25% = 2.5%, yielding 24.375 MPG
That is alot less than the 10% claim from masrum, hence my confusion...
onewhippedpuppy 04-17-2008 04:47 AM
I knew someone whould chime in with a nice ME thermodynamics answer, thanks Red Beard! Thermodynamics..........*shudder*.
