-   -   How to sand drywall without making a huge mess? (http://forums.pelicanparts.com/off-topic-discussions/406195-how-sand-drywall-without-making-huge-mess.html)
VaSteve 04-27-2008 09:55 AM
I need to sand a patch that made in the ceiling. A pretty big section. I have been putting it off since it's going to make a huge mess if I sand it. How can I do this without creating a major mess?
Shadetree930 04-27-2008 09:57 AM
A damp cotton bath towel. Rinse frequently.
competentone 04-27-2008 09:59 AM
Vacuum sander. You don't even need to wear a dust mask.
A simple one like this one works fine:
http://www.acehardware.com/sm-fibatape-and-reg-vacuum-drywall-sander-sv303u--pi-1289091.html
You need to clean the vacuum filter very regularly, with any extended use, but it is so much better -- and faster -- than sealing off the repair area and cleaning up the dust afterward.
Edit: You also should need very little sanding if you've applied multiple coats of drywall mud and feathered it out properly with a wide trowel.
