Electric clothes drier repair...anybody got a website to trouble shoot?
Stopped blowing warm air suddenly. Got any ideas of where to start? I'm not an appliance repair kinda guy...its about 5 years old. Thermostat? Heating element? Just get another drier?
Put an ohm meter on the heating element?
Do a search on the forums for your model # here Samurai Appliance Repair Man It cost $5 to join but the existing posts would be helpful along with the parts diagrams.
Rick 88 Cab |
Detached Member
Samurai is great, solved my dishwasher and icemaker problems very fast.
Hugh |
Check the thermostat resistor. If you run the dryer 3-4x in a row, it could blow it. It's about a $5-$10 part.
Do a google search for appliance repair and you'll find some sites with pictures and how to locate it. Won't take you but 15min.
1989 Carrera Hookem Horns! |
I've bought parts from A1 appliance for several things over the years and gotten help troubleshooting.
http://a-1appliance.com/ The last time my 'fridge had a problem, this place was instrumental in me figuring out the problem http://www.applianceaid.com/ Also, if you do a search for "appliance repair" you get a bunch of hits.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
Thanks guys..fixed it with new thermostats. $22 at local appliance store.
Control Group
my dryer does that when the breaker trips in the summertime. Works, but won't heat up, kinda trippy
She was the kindest person I ever met |
How is it wired? It should be on a double breaker, they both go at once. Sounds to me like one leg is tripping allowing the 120v to still operate the motor. You need to check this and the rest of the wiring.
Control Group
just as you say milt, two thirty amp fuses linked together by a little metal collar
Yup..that was the first thing I checked. More common than you think. Especially if the breaker is tripping. I had never had a clothes drier fail, so I was suprised at how simple it was. On the heating element side there are very few things to fail. A fuse, two thermostats and the heating element. Used a multi-tester and found no continuity on the thermostat so there was the problem. Took all of 10 minutes. And saved me a $65 service call. Last edited by Dueller; 04-29-2008 at 11:46 AM.. |
Control Group
It is like a big toaster with a motor to make it spin, sort of like a VW bug
