Hi
Targa Me's Avatar
ABS Scanner for VW/Audi
Hello Everyone,
I'm looking for a scanner to read the ABS code.
What scanner are you using to read ABS for your VW or Audi?
I appreciate the input.
Thanks.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 06-04-2015, 09:00 AM
Aufenbahn's Avatar
Ross-Tech VCDS or VCDS lite. The lite version is free you just have to buy the interface cable for about $10. And have a laptop running XP.
Andy D.
Currently driving 2005 Audi A4
Currently driving 2006 Ram 1500 sometimes
Old 06-04-2015, 09:09 AM
Hell Belcho
Nostril Cheese's Avatar
Been wondering about this too. Thanks
Old 06-04-2015, 11:23 AM
Shifter's Avatar
You are local, I have the K11-USB if you want to try it. Only works on older cars, though.
Ross-Tech Store: VCDS License with KII-USB Unlimited VIN (VW to ~'05; Audi to ~'03)
Old 06-04-2015, 04:37 PM
Hell Belcho
Perfect, man!
I have an '03 Jetta with an ABS light.
I'll PM you.
Old 06-04-2015, 06:32 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Bought this jobbie on e-bay. Plugs into OBD port. Engine, trans, ABS, air bags.
Most importantly it can clear ABS codes, which on at least the several early 2000's I have fixed, can be the sole problem.
Also they give you a book of the VagCom codes which provides more info than OBD codes. Not loads of info, just other things that can be throwing the code. E.g., If you have a VW you have probably had a coolant temp sensor code. It can also be the thermostat at fault which OBD does not reference.
http://www.ebay.com/itm/VAG-Scanner-Code-Reader-Airbag-Reset-SRS-ABS-Scan-Tool-COM-CAN-BUS-K-Line-Device-/151297642485?hash=item233a0acff5&item=151297642485&vxp=mtr
1981 911SC Targa
Old 06-04-2015, 06:39 PM
+1 on VCDS - I've been using that for years.
Old 06-05-2015, 06:51 PM
Cooper911SC's Avatar
Here's another cheap choice, no interface cable or laptop required...
Used this recently to turn off an airbag light (yes I fixed the problem first )😃 on an '03 GTI.
Scan tool U281. Very inexpensive on Amazon. Clearly not a diagnostic tool, just basic P code reader and MIL light reset tool.
Covers various Audi/VW/Seat/Skoda models.
Cooper
Edit: Bobs link is a very similar reader to what I bought. Basic, but gets 'er done.
Old 06-05-2015, 10:34 PM
