-   -   How to Create a simple, single password in Dreamweaver? (http://forums.pelicanparts.com/off-topic-discussions/413176-how-create-simple-single-password-dreamweaver.html)
RKC 06-05-2008 02:46 PM
I'm finally (I know, I know) migrating from GoLive to Dreamweaver, and just need to make a form with a single, simple password to protect an exam from prying eyes. I am a "pretty colors" sort of guy - I love Illustrator, InDesign and Photoshop, etc., but don't know code.
So what's the deal? I can make the form, found the password field to make the text turn to dots, but how do you assign a value for the password? Can you just protect a page? Can I do a sign up form with a password that leads to another form? Don't care how it's done, really - and I'm not worried about REAL security (no payments, just a test I'm giving that won't change for a year - so I don't want others to see it until they are really taking it). But the test will be a form too, so I can't just do a locked *.pdf.
Help!
FWIW - I'm finally leaving Live Motion 2 also (Adobe's old Flash creator) for Flash CS3 too. A summer of re-learning.....
slodave 06-05-2008 02:56 PM
Can you put the page you want into a new sub directory? If so, use htaccess.
http://www.javascriptkit.com/howto/htaccess3.shtml
If you use a field, then you would have to use javascript, perl or php to make read the password field.
In php, it would look something like this:
If the password field has a name of password and the password is "test1234", then when variable is passed to the next page, the php code would...
$variable = $password;
PHP Code:
if ($variable == 'test1234') {
echo
"that is the correct password.";
} else {
echo
"Sorry, you loose!";
Dave
RKC 06-05-2008 03:15 PM
Wow! Thanks for the quick response. I cut and pasted the code and it worked great!
I'll try the htaccess too.
But even the link you sent seems secure enough for what I want.
Thanks again.
RKC 06-05-2008 03:21 PM
BTW - this is best site, hands down, for ANY QUESTION.
Thanks again, slodave! (And Wayne!)
slodave 06-05-2008 04:11 PM
I'm glad it worked. I forgot to put in the corresponding [INPUT TYPE=PASSWORD NAME=password] for the first page.
rattlsnak 06-05-2008 04:20 PM
BTW, if youre using DW, it will write all the PHP code for you in Design mode. No need to "learn" code! ;)
RKC 06-05-2008 05:36 PM
Thanks for the tip. I can cut and paste code - thanks again slowdave - but don't know how to write it - except for some basic way back when.....
Haven't got the htaccess/password stuff to work. Will try again Friday.
RKC 06-05-2008 05:38 PM
One more question though:
If I just cut and paste the simplest code, can't anyone just do the "view source" thing and SEE the password?
I'm dealing with medical doctors in their 40's & 50's mainly, so not really an issue, but I'm curious....
slodave 06-05-2008 05:41 PM
No, the php code will not be visible, only the HTML it displays. The hidden input takes a value (test1234) and passes that in the headers as a variable to the next page.
slodave 06-05-2008 05:54 PM
Here's a simple php/HTML page...
First Page:
PHP Code:
<?php
print "<HTML>\n";
print
"<TITLE>My Page</TITLE>\n";
print
"<BODY>\n";
print
"<FORM ACTION=nextpage.php METHOD=POST>\n";
print
"Please enter a the password<BR />\n";
print
"<INPUT TYPE=PASSWORD NAME=password>\n";
print
"</FORM>\n";
print
"</BODY>\n";
print
"</HTML>\n";
nextpage.php...
PHP Code:
<?php
$variable
=$password;
if (
print
"<HTML>\n";
print
"<TITLE>Page 2</TITLE>\n";
print
"<BODY>\n";
print
"Password is correct.<BR />\n";
print
"Your data goes here.\n";
print
"</BODY>\n";
print
"</HTML>\n";
} else {
print
"Password is invalid";
slodave 06-05-2008 05:58 PM
I'll write the two pages for you, if you want...
