Go Back   Pelican Parts Technical BBS > 5 - Miscellaneous > Off Topic Discussions
Slackerous Maximus
HardDrive's Avatar
Seat removal, 71 super beetle. Help!
EDIT: solved. Thanks for the help guys.
I am about to lose my mind.
I am trying to get the driver seat out of my 71 beetle. I bought rebuilt replacements. As far as can tell, all that holds the seat in is a lever on the right side, and a spring. The spring is detached, the lever is turned and the teeth that hold the seat in are completely off. But it catches when its about 2/3 of the way off. Its catching on the inboard rail. Is there some hidden thing I need to disengage?
Please someone help me before I do something violent involving a tow chain and my F150.
2004 Royal Enfield Bullet, dripin' oil like an old flat six.
1992 Ducati Supersport. White frame, Ferracci pipes, open airbox.
Mercedes E350 family truckster.
2003 Mustang Mach 1 with Cherry Bomb exhaust
Old 06-21-2008, 11:14 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Feelin' Solexy
Tishabet's Avatar
I've had a 73 and 74 and have removed the seats in both, but I know there was a change in the manner of seat attachment somewhere around 70 (having bought pans for meant for a 60's car and having to retrofit the hardware to fit my 73) so this info may or may not be helpful... in the 73 and 74 there are rails on both sides of the pan (one against the center tube, one against the heater channel/door sill) and a sort of hump in the center of the pan where there is a captured pin (attached to the spring and lever combo you reference) which allows you to adjust/lock the seat.
First things first: If you're seats are like mine in the 73 and 74, there are plastic caps that go on the ends of the rails on each side of the seat which need to be removed before the seat can be removed. Also, sometimes there is scale rust or a coin which gets captured in these rails and causes the seat to bind when moving forward or backward.
The procedure as I recall it is to remove the plastic caps, vacuum out the rails to remove any particles of rust etc, have someone hold the adjustment lever back and slide the entire seat forward until it is off all three rails (the left, right and center rails).
I know there are plenty of VW fans on this board... don't pull out the F150 yet!
Grant
1974 Vespa Rally 200, 1974 Vespa Primavera 125, 1963 Solex 2200, 1938 Buick Special, 2008 Mini Cooper S, 2010 Mazda CX-9, 1986 VW Vanagon Syncro Westfalia - in the stable
1989 Porsche 944, 1973 VW Beetle - gone but not forgotten
Old 06-21-2008, 11:58 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Feelin' Solexy
Tishabet's Avatar
The Samba references a tab that needs to be depressed...
http://www.thesamba.com/vw/forum/viewtopic.php?t=45461&highlight=seats
http://www.thesamba.com/vw/forum/viewtopic.php?t=284664&highlight=front+seats
Grant
Old 06-21-2008, 12:24 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Feelin' Solexy
Tishabet's Avatar
Here's a page from the 1971 owners manual (rest of manual is HERE)
Grant
Old 06-21-2008, 12:25 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Slackerous Maximus
HardDrive's Avatar
Got the seat out....then realized that the seats I have bought, which the seller ASSURED me would fit in my 71, DO NOT FIT. Fuuuuuuuuuuuccccccccckkkkkkk.
Old 06-21-2008, 12:36 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
