-   -   Need Help rear seat removal (http://forums.pelicanparts.com/off-topic-discussions/422101-need-help-rear-seat-removal.html)
ShakinJoe 07-27-2008 11:40 AM
I need some advice on how to get the fasteners out that hold to rear seats to the outside. It is about 3/4 inch in dia and has a big flat screwdriver slot. Yes I have tried a screwdriver.
Shaun @ Tru6 07-27-2008 11:52 AM
Joe, you need the biggest screwdriver you have, insert and twist while tapping the handle with a hammer. You can also try clamping a vice grip on the shaft to give you more leverage, but be sure you are pressing in, maybe get a helper to tap as well.
if those don't work, you'll need an impact driver.
http://forums.pelicanparts.com/uploa...1217184849.jpg
