Home of the Whopper
Hydraulic fluid for mid rise lift
So I just bought a mid rise lift. It needs a gallon of hydraulic fluid. What should I use and where can I get it? Can I just buy a gallons worth of brake fluid?
Thanks!
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 10-13-2008, 07:34 AM
my local parts store has it in gallon containers.
206 637 4071
Old 10-13-2008, 07:49 AM
Do not use brake fluid! I have the fluid spec for my lift written the the fluid tank, if nobody comes through with the info during the workday.
Old 10-13-2008, 07:50 AM
MAGA
Tim Hancock's Avatar
Pretty sure my BendPak midrise lift called for simply ATF. Dexron III I believe. I have been using it several times a week for a couple years now with no problems.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 10-13-2008, 08:03 AM
Targa, Panamera Turbo
M.D. Holloway's Avatar
BK911 - send me a PM and I will get you some at no charge...
Michael D. Holloway
https://5thorderindustry.com/
Old 10-13-2008, 08:31 AM
Actually, ATF or even engine oil will work fine. I would say half of the Cats you see digging holes use engine oil as hydraulic fluid.
Michael D. Holloway
Old 10-13-2008, 08:32 AM
Home of the Whopper
Thanks guys. The instructions simply say a quality hydraulic fluid. None of the local FLAPS had anything but brake fluid.
Old 10-13-2008, 09:23 AM
